Das Perfekte Setup - CentOS 4.4 (32-bit) - Seite 5
10 Postfix mit SMTP-AUTH und TLS
Nun installieren wir Postfix und dovecot (dovecot wird unser POP3/IMAP Server sein):
yum install cyrus-sasl cyrus-sasl-devel cyrus-sasl-gssapi cyrus-sasl-md5 cyrus-sasl-plain postfix dovecot
Als Nächstes konfigurieren wir SMTP-AUTH und TLS:
postconf -e 'smtpd_sasl_local_domain ='
postconf -e 'smtpd_sasl_auth_enable = yes'
postconf -e 'smtpd_sasl_security_options = noanonymous'
postconf -e 'broken_sasl_auth_clients = yes'
postconf -e 'smtpd_recipient_restrictions = permit_sasl_authenticated,permit_mynetworks,reject_unauth_destination'
postconf -e 'inet_interfaces = all'
postconf -e 'mynetworks = 127.0.0.0/8'
Wir müssen /usr/lib/sasl2/smtpd.conf bearbeiten, sodass Postfix PLAIN und LOGIN Logins zulässt. Auf einem 64Bit Centos 4.4 musst Du stattdessen die Datei /usr/lib64/sasl2/smtpd.conf bearbeiten. So sollte es aussehen:
vi /usr/lib/sasl2/smtpd.conf
pwcheck_method: saslauthd
mech_list: plain login
mkdir /etc/postfix/ssl
cd /etc/postfix/ssl/
openssl genrsa -des3 -rand /etc/hosts -out smtpd.key 1024
chmod 600 smtpd.key
openssl req -new -key smtpd.key -out smtpd.csr
openssl x509 -req -days 3650 -in smtpd.csr -signkey smtpd.key -out smtpd.crt
openssl rsa -in smtpd.key -out smtpd.key.unencrypted
mv -f smtpd.key.unencrypted smtpd.key
openssl req -new -x509 -extensions v3_ca -keyout cakey.pem -out cacert.pem -days 3650
postconf -e 'smtpd_tls_auth_only = no'
postconf -e 'smtp_use_tls = yes'
postconf -e 'smtpd_use_tls = yes'
postconf -e 'smtp_tls_note_starttls_offer = yes'
postconf -e 'smtpd_tls_key_file = /etc/postfix/ssl/smtpd.key'
postconf -e 'smtpd_tls_cert_file = /etc/postfix/ssl/smtpd.crt'
postconf -e 'smtpd_tls_CAfile = /etc/postfix/ssl/cacert.pem'
postconf -e 'smtpd_tls_loglevel = 1'
postconf -e 'smtpd_tls_received_header = yes'
postconf -e 'smtpd_tls_session_cache_timeout = 3600s'
postconf -e 'tls_random_source = dev:/dev/urandom'
Nach diesen Konfigurationsschritten solltest Du nun eine Datei /etc/postfix/main.cf haben, die wie folgt aussieht (ich habe alle Kommentare entfernt):
vi /etc/postfix/main.cf
queue_directory = /var/spool/postfix
command_directory = /usr/sbin daemon_directory = /usr/libexec/postfix mail_owner = postfix inet_interfaces = all mydestination = $myhostname, localhost.$mydomain, localhost unknown_local_recipient_reject_code = 550 alias_maps = hash:/etc/aliases alias_database = hash:/etc/aliases debug_peer_level = 2 debugger_command = PATH=/bin:/usr/bin:/usr/local/bin:/usr/X11R6/bin xxgdb $daemon_directory/$process_name $process_id & sleep 5 sendmail_path = /usr/sbin/sendmail.postfix newaliases_path = /usr/bin/newaliases.postfix mailq_path = /usr/bin/mailq.postfix setgid_group = postdrop html_directory = no manpage_directory = /usr/share/man sample_directory = /usr/share/doc/postfix-2.1.5/samples readme_directory = /usr/share/doc/postfix-2.1.5/README_FILES smtpd_sasl_local_domain = smtpd_sasl_auth_enable = yes smtpd_sasl_security_options = noanonymous broken_sasl_auth_clients = yes smtpd_recipient_restrictions = permit_sasl_authenticated,permit_mynetworks,reject_unauth_destination mynetworks = 127.0.0.0/8 smtpd_tls_auth_only = no smtp_use_tls = yes smtpd_use_tls = yes smtp_tls_note_starttls_offer = yes smtpd_tls_key_file = /etc/postfix/ssl/smtpd.key smtpd_tls_cert_file = /etc/postfix/ssl/smtpd.crt smtpd_tls_CAfile = /etc/postfix/ssl/cacert.pem smtpd_tls_loglevel = 1 smtpd_tls_received_header = yes smtpd_tls_session_cache_timeout = 3600s tls_random_source = dev:/dev/urandom
CentOS' dovecot daemon bietet standardmäßig nur IMAP und IMAPs Dienste an. Da wir aber auch POP3 und POP3s möchten, müssen wir dovecot dementsprechend konfigurieren. Wir bearbeiten /etc/dovecot.conf und fügen die Zeile protocols = imap imaps pop3 pop3s ein:
vi /etc/dovecot.conf
# Base directory where to store runtime data. #base_dir = /var/run/dovecot/ # Protocols we want to be serving: # imap imaps pop3 pop3s protocols = imap imaps pop3 pop3s # IP or host address where to listen in for connections. It's not currently # possible to specify multiple addresses. "*" listens in all IPv4 interfaces. [...]
Starte nun Postfix, saslauthd und dovecot:
chkconfig --levels 235 sendmail off
chkconfig --levels 235 postfix on
chkconfig --levels 235 saslauthd on
chkconfig --levels 235 dovecot on
/etc/init.d/sendmail stop
/etc/init.d/postfix start
/etc/init.d/saslauthd start
/etc/init.d/dovecot start
Um herauszufinden, ob SMTP-AUTH und TLS richtig funktionieren, führen wir nun folgenden Befehl aus:
telnet localhost 25
Nachdem Du die Verbindung zu Deinem Postfix Mail Server aufgebaut hast, tippe
ehlo localhost
Wenn Du die Zeile
250-STARTTLS
und
250-AUTH
siehst, ist alles in Ordnung.
Tippe
quit
um zur Kommandozeile des Systems zurückzukehren.
10.1 Maildir
dovecot verwendet ein Maildir Format (nicht mbox), wenn Du also ISPConfig auf dem Server installierst, pass bitte auf, dass Du Maildir unter Management -> Server -> Settings -> Email aktivierst. ISPConfig nimmt dann die notwendige Konfiguration vor.
Wenn Du ISPConfig nicht installieren möchtest, dann musst Du Postfix so konfigurieren, dass es E-Mails an eine Maildir des Benutzers sendet:
postconf -e 'home_mailbox = Maildir/'
postconf -e 'mailbox_command ='
/etc/init.d/postfix restart
1 Kommentar(e)
Von: Der_Paul
Auch wenn das Howto nicht mehr aktuell ist vermisse ich denoch einen Teil zu Procmail. Oder bin ich einfach nur blind?
