Der perfekte Server – Debian Lenny (Debian 5.0) [ISPConfig 3] mit Dovecot und Bind - Seite 5
17 Installieren von SquirrelMail
Um SquirrelMail webmail client zu installieren, starte
apt-get install squirrelmail
dann erstelle den folgenden Symlink für Squirrelmail und einen für PHPmyAdmin…
ln -s /usr/share/squirrelmail/ /var/www/webmail
ln -s /usr/share/phpmyadmin/ /var/www/phpmyadmin
…und konfiguriere SquirrelMail:
squirrelmail-configure
Wir müssen  SquirrelMail sagen, das wir Courier-IMAP/-POP3 benutzen:
SquirrelMail Configuration : Read: config.php (1.4.0)
Main Menu –
1.  Organization Preferences
2.  Server Settings
3.  Folder Defaults
4.  General Options
5.  Themes
6.  Address Books
7.  Message of the Day (MOTD)
8.  Plugins
9.  Database
10. Languages
D.  Set pre-defined settings for specific IMAP servers
C   Turn color on
S   Save data
Q   Quit
Gib ein: D
While we have been building SquirrelMail, we have discovered some
preferences that work better with some servers that don’t work so
well with others.  If you select your IMAP server, this option will
set some pre-defined settings for that server.
Please note that you will still need to go through and make sure
everything is correct.  This does not change everything.  There are
only a few settings that this will change.
Please select your IMAP server:
bincimap    = Binc IMAP server
courier     = Courier IMAP server
cyrus       = Cyrus IMAP server
dovecot     = Dovecot Secure IMAP server
exchange    = Microsoft Exchange IMAP server
hmailserver = hMailServer
macosx      = Mac OS X Mailserver
mercury32   = Mercury/32
uw          = University of Washington’s IMAP server
quit        = Do not change anything
Gib ein: dovecot
imap_server_type = courier
default_folder_prefix = INBOX.
trash_folder = Trash
sent_folder = Sent
draft_folder = Drafts
show_prefix_option = false
default_sub_of_inbox = false
show_contain_subfolders_option = false
optional_delimiter = .
delete_folder = true
Press any key to continue… <– Taste drücken
Main Menu –
2.  Server Settings
3.  Folder Defaults
4.  General Options
5.  Themes
6.  Address Books
8.  Plugins
9.  Database
10. Languages
C   Turn color on
S   Save data
Q   Quit
Eingabe: S
Main Menu –
2.  Server Settings
3.  Folder Defaults
4.  General Options
5.  Themes
6.  Address Books
8.  Plugins
9.  Database
10. Languages
C   Turn color on
S   Save data
Q   Quit
Eingabe>> <– Q
Anschließend kannst du SquirrelMail unter http://server1.example.com/webmail oder http://192.168.0.100/webmail erreichen:
18 Installation von ISPConfig 3
ISPConfig 3 kann von der letzten erschienen Version installiert werden (.tar.gz).
Um es von der letzten erschienen Released zu erstellen, gehe wie folgt vor:
cd /tmp
wget http://www.ispconfig.org/downloads/ISPConfig-3.0.2.tar.gz
tar xvfz ISPConfig-3.0.2.tar.gz
Wir starten nun den Installer von ISPConfig3:
php -q install.php
>> Initial configuration
Operating System: Debian Lenny or compatible
Following will be a few questions for primary configuration so be careful.
Default values are in [brackets] and can be accepted with <ENTER>.
Tap in "quit" (without the quotes) to stop the installer.
Select language (en,de) [en]: de
Installation mode (standard,expert) [standard]:
Full qualified hostname (FQDN) of the server, eg server1.domain.tld [testispconfig.nixhelp.de]:
MySQL server hostname [localhost]:
MySQL root username [root]:
MySQL root password []: monstermegahammergeheimespasswort
MySQL database to create [dbispconfig]:
MySQL charset [utf8]:
Generating a 2048 bit RSA private key
writing new private key to 'smtpd.key'
Country Name (2 letter code) [AU]:DE
State or Province Name (full name) [Some-State]:
Locality Name (eg, city) []:
Organization Name (eg, company) [Internet Widgits Pty Ltd]:
Organizational Unit Name (eg, section) []:
Common Name (eg, YOUR name) []:testispconfig.nixhelp.de
Email Address []:chef@vomserver.de
Configuring Jailkit
Configuring SASL
Configuring PAM
Configuring Dovecot
Configuring Spamassassin
Configuring Amavisd
Configuring Getmail
Configuring Pureftpd
Configuring BIND
Configuring Apache
Configuring vlogger
Configuring Apps vhost
Configuring Firewall
Installing ISPConfig
ISPConfig Port [8080]:
Configuring DBServer
Installing Crontab
no crontab for root
no crontab for getmail
Restarting services ...
Stopping MySQL database server: mysqld.
Starting MySQL database server: mysqld.
Checking for corrupt, not cleanly closed and upgrade needing tables..
Stopping Postfix Mail Transport Agent: postfix.
Starting Postfix Mail Transport Agent: postfix.
Stopping SASL Authentication Daemon: saslauthd.
Starting SASL Authentication Daemon: saslauthd.
Stopping amavisd: amavisd-new.
head: cannot open `/etc/mailname' for reading: No such file or directory
Starting amavisd: amavisd-new.
Stopping ClamAV daemon: clamd.
Starting ClamAV daemon: clamd .
Restarting IMAP/POP3 mail server: dovecot.
Restarting web server: apache2 ... waiting ..
Restarting ftp server: Running: /usr/sbin/pure-ftpd-mysql-virtualchroot -l mysql:/etc/pure-ftpd/db/mysql.conf -l pam -b -E -p 4000:4020 -u 1000 -A -O clf:/var/log/pure-ftpd/transfer.log -Y 1 -H -B
Installation completed.
server1:/tmp/ispconfig3_install/install#
Der Installer konfiguriert alle untergeordneten Services, sodass es keiner manuellen Konfiguration bedarf.
Anschließend kannst du  ISPConfig 3 unter http://server1.example.com:8080/ oder http://192.168.0.100:8080/ erreichen. Logge dich mit dem Benutzernamen admin und dem Passwort admin (Du solltest den Standard nach dem ersten log-in ändern) ein:
Das System kann nun benutzt werden.
19. Hinweiss für Debian unter OpenVz
a)
VPSID=101
for CAP in CHOWN DAC_READ_SEARCH SETGID SETUID NET_BIND_SERVICE NET_ADMIN SYS_CHROOT SYS_NICE CHOWN DAC_READ_SEARCH SETGID SETUID NET_BIND_SERVICE NET_ADMIN SYS_CHROOT SYS_NICE
do
vzctl set $VPSID --capability ${CAP}:on --save
done
b) Pureftp
PureFTPD greift auf gewisse Schnittstellen zurück, die der virtuellen Maschine nicht vom Standard aus gegeben sind.
Hierzu muss im Host die Config der virtuellen Maschine bearbeitet bzw. ergänzt werden.
Die Configs liegen unter /etc/vz/config
vi /etc/config
CAPABILITY=”CHOWN:on DAC_READ_SEARCH:on SETGID:on SETUID:on NET_BIND_SERVICE:on NET_ADMIN:on SYS_CHROOT:on SYS_NICE:on “
20. Links
Bitte benutze die Kommentarfunktion nicht für Fragen, sondern nutze das Forum dazu.
