Tutorial: PHP5 mit Suhosin auf Mandriva 2007 Spring sicherer machen
Diese Anleitung veranschaulicht, wie man PHP5 mit Suhosin auf einem Mandriva 2007 Spring Server sicherer machen kann. Von der Suhosin Projekt Seite: “Suhosin is an advanced protection system for PHP installations that was designed to protect servers and users from known and unknown flaws in PHP applications and the PHP core. Suhosin comes in two independent parts, that can be used separately or in combination. The first part is a small patch against the PHP core, that implements a few low-level protections against buffer overflows or format string vulnerabilities and the second part is a powerful PHP extension that implements all the other protections.” Mehr... »
