Virtuelle Benutzer und Domains mit Postfix, Courier und MySQL (Fedora Core 5) - Seite 3
Nach meinen Änderungen sieht /etc/amavisd/amavisd.conf wie folgt aus:
use strict;
# a minimalistic configuration file for amavisd-new with all necessary settings # # see amavisd.conf-default for a list of all variables with their defaults; # see amavisd.conf-sample for a traditional-style commented file; # for more details see documentation in INSTALL, README_FILES/* # and at http://www.ijs.si/software/amavisd/amavisd-new-docs.html # COMMONLY ADJUSTED SETTINGS: # @bypass_virus_checks_maps = (1); # uncomment to DISABLE anti-virus code # @bypass_spam_checks_maps = (1); # uncomment to DISABLE anti-spam code $max_servers = 2; # num of pre-forked children (2..15 is common), -m $daemon_user = 'amavis'; # (no default; customary: vscan or amavis), -u $daemon_group = 'amavis'; # (no default; customary: vscan or amavis), -g ######################## $mydomain = 'localhost'; ######################## #$mydomain = 'example.com'; # a convenient default for other settings $MYHOME = '/var/spool/amavisd'; # a convenient default for other settings, -H $TEMPBASE = "$MYHOME/tmp"; # working directory, needs to exist, -T $ENV{TMPDIR} = $TEMPBASE; # environment variable TMPDIR $QUARANTINEDIR = undef; # -Q # $quarantine_subdir_levels = 1; # add level of subdirs to disperse quarantine # $daemon_chroot_dir = $MYHOME; # chroot directory or undef, -R # $db_home = "$MYHOME/db"; # dir for bdb nanny/cache/snmp databases, -D # $helpers_home = "$MYHOME/var"; # working directory for SpamAssassin, -S $lock_file = "/var/run/amavisd/amavisd.lock"; # -L $pid_file = "/var/run/amavisd/amavisd.pid"; # -P #NOTE: create directories $MYHOME/tmp, $MYHOME/var, $MYHOME/db manually @local_domains_maps = ( [".$mydomain"] ); # @mynetworks = qw( 127.0.0.0/8 [::1] [FE80::]/10 [FEC0::]/10 # 10.0.0.0/8 172.16.0.0/12 192.168.0.0/16 ); $log_level = 0; # verbosity 0..5, -d $log_recip_templ = undef; # disable by-recipient level-0 log entries $DO_SYSLOG = 1; # log via syslogd (preferred) $syslog_facility = 'mail'; # Syslog facility as a string # e.g.: mail, daemon, user, local0, ... local7 $syslog_priority = 'debug'; # Syslog base (minimal) priority as a string, # choose from: emerg, alert, crit, err, warning, notice, info, debug $enable_db = 1; # enable use of BerkeleyDB/libdb (SNMP and nanny) $enable_global_cache = 1; # enable use of libdb-based cache if $enable_db=1 $inet_socket_port = 10024; # listen on this local TCP port(s) (see $protocol) $unix_socketname = "$MYHOME/amavisd.sock"; # amavisd-release or amavis-milter # option(s) -p overrides $inet_socket_port and $unix_socketname $interface_policy{'SOCK'}='AM.PDP-SOCK'; # only relevant with $unix_socketname # Use with amavis-release over a socket or with Petr Rehor's amavis-milter.c # (with amavis-milter.c from this package or old amavis.c client use 'AM.CL'): $policy_bank{'AM.PDP-SOCK'} = { protocol=>'AM.PDP' }; ######################## $sa_tag_level_deflt = 2.0; # add spam info headers if at, or above that level $sa_tag2_level_deflt = 4.0; # add 'spam detected' headers at that level $sa_kill_level_deflt = $sa_tag2_level_deflt; # triggers spam evasive actions $sa_dsn_cutoff_level = 10; # spam level beyond which a DSN is not sent ######################## # $sa_quarantine_cutoff_level = 20; # spam level beyond which quarantine is off # $penpals_bonus_score = 4; # (no effect without a @storage_sql_dsn database) # $penpals_threshold_high = $sa_kill_level_deflt; # don't waste time on hi spam $sa_mail_body_size_limit = 512*1024; # don't waste time on SA if mail is larger $sa_local_tests_only = 0; # only tests which do not require internet access? # @lookup_sql_dsn = # ( ['DBI:mysql:database=mail;host=127.0.0.1;port=3306', 'user1', 'passwd1'], # ['DBI:mysql:database=mail;host=host2', 'username2', 'password2'], # ["DBI:SQLite:dbname=$MYHOME/sql/mail_prefs.sqlite", '', ''] ); ######################## @lookup_sql_dsn = ( ['DBI:mysql:database=mail;host=127.0.0.1;port=3306', 'mail_admin', 'mail_admin_password'] ); $sql_select_policy = 'SELECT "Y" as local FROM domains WHERE CONCAT("@",domain) IN (%k)'; $sql_select_white_black_list = undef; # undef disables SQL white/blacklisting $recipient_delimiter = '+'; # (default is '+') $replace_existing_extension = 1; # (default is false) $localpart_is_case_sensitive = 0; # (default is false) ######################## # @storage_sql_dsn = @lookup_sql_dsn; # none, same, or separate database # $timestamp_fmt_mysql = 1; # if using MySQL *and* msgs.time_iso is TIMESTAMP; # defaults to 0, which is good for non-MySQL or if msgs.time_iso is CHAR(16) $virus_admin = undef; # notifications recip. $mailfrom_notify_admin = undef; # notifications sender $mailfrom_notify_recip = undef; # notifications sender $mailfrom_notify_spamadmin = undef; # notifications sender $mailfrom_to_quarantine = ''; # null return path; uses original sender if undef @addr_extension_virus_maps = ('virus'); @addr_extension_spam_maps = ('spam'); @addr_extension_banned_maps = ('banned'); @addr_extension_bad_header_maps = ('badh'); ######################## $recipient_delimiter = undef; # undef disables address extensions altogether # when enabling addr extensions do also Postfix/main.cf: recipient_delimiter=+ ######################## $path = '/usr/local/sbin:/usr/local/bin:/usr/sbin:/sbin:/usr/bin:/bin'; # $dspam = 'dspam'; $MAXLEVELS = 14; $MAXFILES = 1500; $MIN_EXPANSION_QUOTA = 100*1024; # bytes (default undef, not enforced) $MAX_EXPANSION_QUOTA = 300*1024*1024; # bytes (default undef, not enforced) $sa_spam_subject_tag = '***SPAM*** '; $defang_virus = 1; # MIME-wrap passed infected mail $defang_banned = 1; # MIME-wrap passed mail containing banned name # OTHER MORE COMMON SETTINGS (defaults may suffice): # $myhostname = 'host.example.com'; # must be a fully-qualified domain name! # $notify_method = 'smtp:[127.0.0.1]:10025'; # $forward_method = 'smtp:[127.0.0.1]:10025'; # set to undef with milter! ######################## $final_virus_destiny = D_REJECT; $final_banned_destiny = D_REJECT; $final_spam_destiny = D_PASS; $final_bad_header_destiny = D_PASS; ######################## # $os_fingerprint_method = 'p0f:127.0.0.1:2345'; # to query p0f-analyzer.pl ## hierarchy by which a final setting is chosen: ## policy bank (based on port or IP address) -> *_by_ccat ## *_by_ccat (based on mail contents) -> *_maps ## *_maps (based on recipient address) -> final configuration value # SOME OTHER VARIABLES WORTH CONSIDERING (see amavisd.conf-default for all) # $warnbadhsender, # $warnvirusrecip, $warnbannedrecip, $warnbadhrecip, (or @warn*recip_maps) # # @bypass_virus_checks_maps, @bypass_spam_checks_maps, # @bypass_banned_checks_maps, @bypass_header_checks_maps, # # @virus_lovers_maps, @spam_lovers_maps, # @banned_files_lovers_maps, @bad_header_lovers_maps, # # @blacklist_sender_maps, @score_sender_maps, # # $clean_quarantine_method, $virus_quarantine_to, $banned_quarantine_to, # $bad_header_quarantine_to, $spam_quarantine_to, # # $defang_bad_header, $defang_undecipherable, $defang_spam # REMAINING IMPORTANT VARIABLES ARE LISTED HERE BECAUSE OF LONGER ASSIGNMENTS @keep_decoded_original_maps = (new_RE( # qr'^MAIL$', # retain full original message for virus checking (can be slow) qr'^MAIL-UNDECIPHERABLE$', # recheck full mail if it contains undecipherables qr'^(ASCII(?! cpio)|text|uuencoded|xxencoded|binhex)'i, # qr'^Zip archive data', # don't trust Archive::Zip )); # for $banned_namepath_re, a new-style of banned table, see amavisd.conf-sample $banned_filename_re = new_RE( # qr'^UNDECIPHERABLE$', # is or contains any undecipherable components # block certain double extensions anywhere in the base name qr'.[^./]*[A-Za-z][^./]*.(exe|vbs|pif|scr|bat|cmd|com|cpl|dll).?$'i, # qr'{[0-9a-f]{8}(-[0-9a-f]{4}){3}-[0-9a-f]{12}}?'i, # Class ID CLSID, strict # qr'{[0-9a-z]{4,}(-[0-9a-z]{4,}){0,7}}?'i, # Class ID extension CLSID, loose qr'^application/x-msdownload$'i, # block these MIME types qr'^application/x-msdos-program$'i, qr'^application/hta$'i, # qr'^(application/x-msmetafile|image/x-wmf)$'i, # Windows Metafile MIME # qr'^.wmf$', # Windows Metafile file(1) type # qr'^message/partial$'i, # rfc2046 MIME type # qr'^message/external-body$'i, # rfc2046 MIME type # [ qr'^.(Z|gz|bz2)$' => 0 ], # allow any in Unix-compressed [ qr'^.(rpm|cpio|tar)$' => 0 ], # allow any in Unix-type archives # [ qr'^.(zip|rar|arc|arj|zoo)$'=> 0 ], # allow any within such archives qr'..(exe|vbs|pif|scr|bat|cmd|com|cpl)$'i, # banned extension - basic # qr'..(ade|adp|app|bas|bat|chm|cmd|com|cpl|crt|emf|exe|fxp|grp|hlp|hta| # inf|ins|isp|js|jse|lnk|mda|mdb|mde|mdw|mdt|mdz|msc|msi|msp|mst| # ops|pcd|pif|prg|reg|scr|sct|shb|shs|vb|vbe|vbs| # wmf|wsc|wsf|wsh)$'ix, # banned ext - long # qr'..(mim|b64|bhx|hqx|xxe|uu|uue)$'i, # banned extension - WinZip vulnerab. qr'^.(exe-ms)$', # banned file(1) types # qr'^.(exe|lha|tnef|cab|dll)$', # banned file(1) types ); # See http://support.microsoft.com/default.aspx?scid=kb;EN-US;q262631 # and http://www.cknow.com/vtutor/vtextensions.htm # ENVELOPE SENDER SOFT-WHITELISTING / SOFT-BLACKLISTING @score_sender_maps = ({ # a by-recipient hash lookup table, # results from all matching recipient tables are summed # ## per-recipient personal tables (NOTE: positive: black, negative: white) # 'user1@example.com' => [{'bla-mobile.press@example.com' => 10.0}], # 'user3@example.com' => [{'.ebay.com' => -3.0}], # 'user4@example.com' => [{'cleargreen@cleargreen.com' => -7.0, # '.cleargreen.com' => -5.0}], ## site-wide opinions about senders (the '.' matches any recipient) '.' => [ # the _first_ matching sender determines the score boost new_RE( # regexp-type lookup table, just happens to be all soft-blacklist [qr'^(bulkmail|offers|cheapbenefits|earnmoney|foryou)@'i => 5.0], [qr'^(greatcasino|investments|lose_weight_today|market.alert)@'i=> 5.0], [qr'^(money2you|MyGreenCard|new.tld.registry|opt-out|opt-in)@'i=> 5.0], [qr'^(optin|saveonlsmoking2002k|specialoffer|specialoffers)@'i => 5.0], [qr'^(stockalert|stopsnoring|wantsome|workathome|yesitsfree)@'i => 5.0], [qr'^(your_friend|greatoffers)@'i => 5.0], [qr'^(inkjetplanet|marketopt|MakeMoney)d*@'i => 5.0], ), # read_hash("/var/amavis/sender_scores_sitewide"), { # a hash-type lookup table (associative array) 'nobody@cert.org' => -3.0, 'cert-advisory@us-cert.gov' => -3.0, 'owner-alert@iss.net' => -3.0, 'slashdot@slashdot.org' => -3.0, 'securityfocus.com' => -3.0, 'ntbugtraq@listserv.ntbugtraq.com' => -3.0, 'security-alerts@linuxsecurity.com' => -3.0, 'mailman-announce-admin@python.org' => -3.0, 'amavis-user-admin@lists.sourceforge.net'=> -3.0, 'amavis-user-bounces@lists.sourceforge.net' => -3.0, 'spamassassin.apache.org' => -3.0, 'notification-return@lists.sophos.com' => -3.0, 'owner-postfix-users@postfix.org' => -3.0, 'owner-postfix-announce@postfix.org' => -3.0, 'owner-sendmail-announce@lists.sendmail.org' => -3.0, 'sendmail-announce-request@lists.sendmail.org' => -3.0, 'donotreply@sendmail.org' => -3.0, 'ca+envelope@sendmail.org' => -3.0, 'noreply@freshmeat.net' => -3.0, 'owner-technews@postel.acm.org' => -3.0, 'ietf-123-owner@loki.ietf.org' => -3.0, 'cvs-commits-list-admin@gnome.org' => -3.0, 'rt-users-admin@lists.fsck.com' => -3.0, 'clp-request@comp.nus.edu.sg' => -3.0, 'surveys-errors@lists.nua.ie' => -3.0, 'emailnews@genomeweb.com' => -5.0, 'yahoo-dev-null@yahoo-inc.com' => -3.0, 'returns.groups.yahoo.com' => -3.0, 'clusternews@linuxnetworx.com' => -3.0, lc('lvs-users-admin@LinuxVirtualServer.org') => -3.0, lc('owner-textbreakingnews@CNNIMAIL12.CNN.COM') => -5.0, # soft-blacklisting (positive score) 'sender@example.net' => 3.0, '.example.net' => 1.0, }, ], # end of site-wide tables }); @decoders = ( ['mail', &do_mime_decode], ['asc', &do_ascii], ['uue', &do_ascii], ['hqx', &do_ascii], ['ync', &do_ascii], ['F', &do_uncompress, ['unfreeze','freeze -d','melt','fcat'] ], ['Z', &do_uncompress, ['uncompress','gzip -d','zcat'] ], ['gz', &do_uncompress, 'gzip -d'], ['gz', &do_gunzip], ['bz2', &do_uncompress, 'bzip2 -d'], ['lzo', &do_uncompress, 'lzop -d'], ['rpm', &do_uncompress, ['rpm2cpio.pl','rpm2cpio'] ], ['cpio', &do_pax_cpio, ['pax','gcpio','cpio'] ], ['tar', &do_pax_cpio, ['pax','gcpio','cpio'] ], ['tar', &do_tar], ['deb', &do_ar, 'ar'], # ['a', &do_ar, 'ar'], # unpacking .a seems an overkill ['zip', &do_unzip], ['rar', &do_unrar, ['rar','unrar'] ], ['arj', &do_unarj, ['arj','unarj'] ], ['arc', &do_arc, ['nomarch','arc'] ], ['zoo', &do_zoo, ['zoo','unzoo'] ], ['lha', &do_lha, 'lha'], # ['doc', &do_ole, 'ripole'], ['cab', &do_cabextract, 'cabextract'], ['tnef', &do_tnef_ext, 'tnef'], ['tnef', &do_tnef], # ['sit', &do_unstuff, 'unstuff'], # broken/unsafe decoder ['exe', &do_executable, ['rar','unrar'], 'lha', ['arj','unarj'] ], ); @av_scanners = ( # ### http://www.vanja.com/tools/sophie/ # ['Sophie', # &ask_daemon, ["{}/n", '/var/run/sophie'], # qr/(?x)^ 0+ ( : | [?00rn]* $)/, qr/(?x)^ 1 ( : | [?00rn]* $)/, # qr/(?x)^ [-+]? d+ : (.*?) [?00rn]* $/ ], # ### http://www.csupomona.edu/~henson/www/projects/SAVI-Perl/ # ['Sophos SAVI', &sophos_savi ], # ### http://www.clamav.net/ ['ClamAV-clamd', &ask_daemon, ["CONTSCAN {}n", "/var/spool/amavisd/clamd.sock"], qr/bOK$/, qr/bFOUND$/, qr/^.*?: (?!Infected Archive)(.*) FOUND$/ ], # # NOTE: the easiest is to run clamd under the same user as amavisd; match the # # socket name (LocalSocket) in clamav.conf to the socket name in this entry # # When running chrooted one may prefer: ["CONTSCAN {}n","$MYHOME/clamd"], # ### http://www.clamav.net/ and CPAN (memory-hungry! clamd is preferred) # ['Mail::ClamAV', &ask_clamav, "*", [0], [1], qr/^INFECTED: (.+)/], # ### http://www.openantivirus.org/ # ['OpenAntiVirus ScannerDaemon (OAV)', # &ask_daemon, ["SCAN {}n", '127.0.0.1:8127'], # qr/^OK/, qr/^FOUND: /, qr/^FOUND: (.+)/ ], # ### http://www.vanja.com/tools/trophie/ # ['Trophie', # &ask_daemon, ["{}/n", '/var/run/trophie'], # qr/(?x)^ 0+ ( : | [?00rn]* $)/, qr/(?x)^ 1 ( : | [?00rn]* $)/, # qr/(?x)^ [-+]? d+ : (.*?) [?00rn]* $/ ], # ### http://www.grisoft.com/ # ['AVG Anti-Virus', # &ask_daemon, ["SCAN {}n", '127.0.0.1:55555'], # qr/^200/, qr/^403/, qr/^403 .*?: ([^rn]+)/ ], # ### http://www.f-prot.com/ # ['FRISK F-Prot Daemon', # &ask_daemon, # ["GET {}/*?-dumb%20-archive%20-packed HTTP/1.0rnrn", # ['127.0.0.1:10200','127.0.0.1:10201','127.0.0.1:10202', # '127.0.0.1:10203','127.0.0.1:10204'] ], # qr/(?i)<summary[^>]*>clean</summary>/, # qr/(?i)<summary[^>]*>infected</summary>/, # qr/(?i)<name>(.+)</name>/ ], # ### http://www.sald.com/, http://www.dials.ru/english/, http://www.drweb.ru/ # ['DrWebD', &ask_daemon, # DrWebD 4.31 or later # [pack('N',1). # DRWEBD_SCAN_CMD # pack('N',0x00280001). # DONT_CHANGEMAIL, IS_MAIL, RETURN_VIRUSES # pack('N', # path length # length("$TEMPBASE/amavis-yyyymmddTHHMMSS-xxxxx/parts/pxxx")). # '{}/*'. # path # pack('N',0). # content size # pack('N',0), # '/var/drweb/run/drwebd.sock', # # '/var/amavis/var/run/drwebd.sock', # suitable for chroot # # '/usr/local/drweb/run/drwebd.sock', # FreeBSD drweb ports default # # '127.0.0.1:3000', # or over an inet socket # ], # qr/Ax00[x10x11][x00x10]x00/s, # IS_CLEAN,EVAL_KEY; SKIPPED # qr/Ax00[x00x01][x00x10][x20x40x80]/s, # KNOWN_V,UNKNOWN_V,V._MODIF # qr/A.{12}(?:infected with )?([^x00]+)x00/s, # ], # # NOTE: If using amavis-milter, change length to: # # length("$TEMPBASE/amavis-milter-xxxxxxxxxxxxxx/parts/pxxx"). ### http://www.kaspersky.com/ (kav4mailservers) ['KasperskyLab AVP - aveclient', ['/usr/local/kav/bin/aveclient','/usr/local/share/kav/bin/aveclient', '/opt/kav/bin/aveclient','aveclient'], '-p /var/run/aveserver -s {}/*', [0,3,6,8], qr/b(INFECTED|SUSPICION)b/, qr/(?:INFECTED|SUSPICION) (.+)/, ], ### http://www.kaspersky.com/ ['KasperskyLab AntiViral Toolkit Pro (AVP)', ['avp'], '-* -P -B -Y -O- {}', [0,3,6,8], [2,4], # any use for -A -K ? qr/infected: (.+)/, sub {chdir('/opt/AVP') or die "Can't chdir to AVP: $!"}, sub {chdir($TEMPBASE) or die "Can't chdir back to $TEMPBASE $!"}, ], ### The kavdaemon and AVPDaemonClient have been removed from Kasperky ### products and replaced by aveserver and aveclient ['KasperskyLab AVPDaemonClient', [ '/opt/AVP/kavdaemon', 'kavdaemon', '/opt/AVP/AvpDaemonClient', 'AvpDaemonClient', '/opt/AVP/AvpTeamDream', 'AvpTeamDream', '/opt/AVP/avpdc', 'avpdc' ], "-f=$TEMPBASE {}", [0,8], [3,4,5,6], qr/infected: ([^rn]+)/ ], # change the startup-script in /etc/init.d/kavd to: # DPARMS="-* -Y -dl -f=/var/amavis /var/amavis" # (or perhaps: DPARMS="-I0 -Y -* /var/amavis" ) # adjusting /var/amavis above to match your $TEMPBASE. # The '-f=/var/amavis' is needed if not running it as root, so it # can find, read, and write its pid file, etc., see 'man kavdaemon'. # defUnix.prf: there must be an entry "*/var/amavis" (or whatever # directory $TEMPBASE specifies) in the 'Names=' section. # cd /opt/AVP/DaemonClients; configure; cd Sample; make # cp AvpDaemonClient /opt/AVP/ # su - vscan -c "${PREFIX}/kavdaemon ${DPARMS}" ### http://www.centralcommand.com/ ['CentralCommand Vexira (new) vascan', ['vascan','/usr/lib/Vexira/vascan'], "-a s --timeout=60 --temp=$TEMPBASE -y $QUARANTINEDIR ". "--vdb=/usr/lib/Vexira/vexira8.vdb --log=/var/log/vascan.log {}", [0,3], [1,2,5], qr/(?x)^s* (?:virus|iworm|macro|mutant|sequence|trojan) found: ( [^]s']+ ) ... / ], # Adjust the path of the binary and the virus database as needed. # 'vascan' does not allow to have the temp directory to be the same as # the quarantine directory, and the quarantine option can not be disabled. # If $QUARANTINEDIR is not used, then another directory must be specified # to appease 'vascan'. Move status 3 to the second list if password # protected files are to be considered infected. ### http://www.hbedv.com/ ['H+BEDV AntiVir or the (old) CentralCommand Vexira Antivirus', ['antivir','vexira'], '--allfiles -noboot -nombr -rs -s -z {}', [0], qr/ALERT:|VIRUS:/, qr/(?x)^s* (?: ALERT: s* (?: [ | [^']* ' ) | (?i) VIRUS: .*? virus '?) ( [^]s']+ )/ ], # NOTE: if you only have a demo version, remove -z and add 214, as in: # '--allfiles -noboot -nombr -rs -s {}', [0,214], qr/ALERT:|VIRUS:/, ### http://www.commandsoftware.com/ ['Command AntiVirus for Linux', 'csav', '-all -archive -packed {}', [50], [51,52,53], qr/Infection: (.+)/ ], ### http://www.symantec.com/ ['Symantec CarrierScan via Symantec CommandLineScanner', 'cscmdline', '-a scan -i 1 -v -s 127.0.0.1:7777 {}', qr/^Files Infected:s+0$/, qr/^Infectedb/, qr/^(?:Info|Virus Name):s+(.+)/ ], ### http://www.symantec.com/ ['Symantec AntiVirus Scan Engine', 'savsecls', '-server 127.0.0.1:7777 -mode scanrepair -details -verbose {}', [0], qr/^Infectedb/, qr/^(?:Info|Virus Name):s+(.+)/ ], # NOTE: check options and patterns to see which entry better applies ### http://www.f-secure.com/products/anti-virus/ ['F-Secure Antivirus', 'fsav', '--dumb --mime --archive {}', [0], [3,8], qr/(?:infection|Infected|Suspected): (.+)/ ], # ### http://www.avast.com/ # ['avast! Antivirus daemon', # &ask_daemon, # greets with 220, terminate with QUIT # ["SCAN {}?15?12QUIT?15?12", '/var/run/avast4/mailscanner.sock'], # qr/t[+]/, qr/t[L]t/, qr/t[L]t([^[ t?15?12]+)/ ], # ### http://www.avast.com/ # ['avast! Antivirus - Client/Server Version', 'avastlite', # '-a /var/run/avast4/mailscanner.sock -n {}', [0], [1], # qr/t[L]t([^[ t?15?12]+)/ ], ['CAI InoculateIT', 'inocucmd', # retired product '-sec -nex {}', [0], [100], qr/was infected by virus (.+)/ ], # see: http://www.flatmtn.com/computer/Linux-Antivirus_CAI.html ### http://www3.ca.com/Solutions/Product.asp?ID=156 (ex InoculateIT) ['CAI eTrust Antivirus', 'etrust-wrapper', '-arc -nex -spm h {}', [0], [101], qr/is infected by virus: (.+)/ ], # NOTE: requires suid wrapper around inocmd32; consider flag: -mod reviewer # see http://marc.theaimsgroup.com/?l=amavis-user&m=109229779912783 ### http://mks.com.pl/english.html ['MkS_Vir for Linux (beta)', ['mks32','mks'], '-s {}/*', [0], [1,2], qr/--[ t]*(.+)/ ], ### http://mks.com.pl/english.html ['MkS_Vir daemon', 'mksscan', '-s -q {}', [0], [1..7], qr/^... (S+)/ ], ### http://www.nod32.com/ ['ESET Software NOD32 Command Line Interface v 2.51', 'nod32cli', '--subdir {}', [0,3], [1,2], qr/virus="([^"]+)"/ ], # ### http://www.nod32.com/ old # ['ESET Software NOD32 - Client/Server Version', 'nod32cli', # '-a -r -d recurse --heur standard {}', [0], [10,11], # qr/^S+s+infected:s+(.+)/ ], # ### http://www.nod32.com/ old # ['ESET Software NOD32', 'nod32', # '--arch --mail {}', [0], [1,10], qr/^object=.*, virus="(.*?)",/ ], # Experimental, based on posting from Rado Dibarbora (Dibo) on 2002-05-31 # ['ESET Software NOD32 Client/Server (NOD32SS)', # &ask_daemon2, # greets with 200, persistent, terminate with QUIT # ["SCAN {}/*rn", '127.0.0.1:8448' ], # qr/^200 File OK/, qr/^201 /, qr/^201 (.+)/ ], ### http://www.norman.com/products_nvc.shtml ['Norman Virus Control v5 / Linux', 'nvcc', '-c -l:0 -s -u -temp:$TEMPBASE {}', [0,10,11], [1,2,14], qr/(?i).* virus in .* -> '(.+)'/ ], ### http://www.pandasoftware.com/ ['Panda Antivirus for Linux', ['pavcl'], '-aut -aex -heu -cmp -nbr -nor -nso -eng {}', qr/Number of files infected[ .]*: 0+(?!d)/, qr/Number of files infected[ .]*: 0*[1-9]/, qr/Found virus :s*(S+)/ ], # ### http://www.pandasoftware.com/ # ['Panda Antivirus for Linux', ['pavcl'], # '-TSR -aut -aex -heu -cmp -nbr -nor -nso -eng {}', # [0], [0x10, 0x30, 0x50, 0x70, 0x90, 0xB0, 0xD0, 0xF0], # qr/Found virus :s*(S+)/ ], # GeCAD AV technology is acquired by Microsoft; RAV has been discontinued. # Check your RAV license terms before fiddling with the following two lines! # ['GeCAD RAV AntiVirus 8', 'ravav', # '--all --archive --mail {}', [1], [2,3,4,5], qr/Infected: (.+)/ ], # # NOTE: the command line switches changed with scan engine 8.5 ! # # (btw, assigning stdin to /dev/null causes RAV to fail) ### http://www.nai.com/ ['NAI McAfee AntiVirus (uvscan)', 'uvscan', '--secure -rv --mime --summary --noboot - {}', [0], [13], qr/(?x) Found (?: the (.+) (?:virus|trojan) | (?:virus|trojan) or variant (.+?)s*! | : (.+) NOT a virus)/, # sub {$ENV{LD_PRELOAD}='/lib/libc.so.6'}, # sub {delete $ENV{LD_PRELOAD}}, ], # NOTE1: with RH9: force the dynamic linker to look at /lib/libc.so.6 before # anything else by setting environment variable LD_PRELOAD=/lib/libc.so.6 # and then clear it when finished to avoid confusing anything else. # NOTE2: to treat encrypted files as viruses replace the [13] with: # qr/^s{5,}(Found|is password-protected|.*(virus|trojan))/ ### http://www.virusbuster.hu/en/ ['VirusBuster', ['vbuster', 'vbengcl'], "{} -ss -i '*' -log=$MYHOME/vbuster.log", [0], [1], qr/: '(.*)' - Virus/ ], # VirusBuster Ltd. does not support the daemon version for the workstation # engine (vbuster-eng-1.12-linux-i386-libc6.tgz) any longer. The names of # binaries, some parameters AND return codes have changed (from 3 to 1). # See also the new Vexira entry 'vascan' which is possibly related. # ### http://www.virusbuster.hu/en/ # ['VirusBuster (Client + Daemon)', 'vbengd', # '-f -log scandir {}', [0], [3], # qr/Virus found = (.*);/ ], # # HINT: for an infected file it always returns 3, # # although the man-page tells a different story ### http://www.cyber.com/ ['CyberSoft VFind', 'vfind', '--vexit {}/*', [0], [23], qr/##==>>>> VIRUS ID: CVDL (.+)/, # sub {$ENV{VSTK_HOME}='/usr/lib/vstk'}, ], ### http://www.avast.com/ ['avast! Antivirus', ['/usr/bin/avastcmd','avastcmd'], '-a -i -n -t=A {}', [0], [1], qr/binfected by:s+([^ tn[]]+)/ ], ### http://www.ikarus-software.com/ ['Ikarus AntiVirus for Linux', 'ikarus', '{}', [0], [40], qr/Signature (.+) found/ ], ### http://www.bitdefender.com/ ['BitDefender', 'bdc', '--arc --mail {}', qr/^Infected files *:0+(?!d)/, qr/^(?:Infected files|Identified viruses|Suspect files) *:0*[1-9]/, qr/(?:suspected|infected): (.*)(?:?33|$)/ ], # consider also: --all --nowarn --alev=15 --flev=15. The --all argument may # not apply to your version of bdc, check documentation and see 'bdc --help' # ['File::Scan', sub {Amavis::AV::ask_av(sub{ # use File::Scan; my($fn)=@_; # my($f)=File::Scan->new(max_txt_size=>0, max_bin_size=>0); # my($vname) = $f->scan($fn); # $f->error ? (2,"Error: ".$f->error) # : ($vname ne '') ? (1,"$vname FOUND") : (0,"Clean")}, @_) }, # ["{}/*"], [0], [1], qr/^(.*) FOUND$/ ], # ### example: fully-fledged checker for JPEG marker segments of invalid length # ['check-jpeg', # sub { use JpegTester (); Amavis::AV::ask_av(&JpegTester::test_jpeg, @_) }, # ["{}/*"], undef, [1], qr/^(bad jpeg: .*)$/ ], # # NOTE: place file JpegTester.pm somewhere where Perl can find it, # # for example in /usr/local/lib/perl5/site_perl ); @av_scanners_backup = ( ### http://www.clamav.net/ - backs up clamd or Mail::ClamAV ['ClamAV-clamscan', 'clamscan', "--stdout --disable-summary -r --tempdir=$TEMPBASE {}", [0], qr/:.*sFOUND$/, qr/^.*?: (?!Infected Archive)(.*) FOUND$/ ], ### http://www.f-prot.com/ - backs up F-Prot Daemon ['FRISK F-Prot Antivirus', ['f-prot','f-prot.sh'], '-dumb -archive -packed {}', [0,8], [3,6], qr/Infection: (.+)|s+containss+(.+)$/ ], ### http://www.trendmicro.com/ - backs up Trophie ['Trend Micro FileScanner', ['/etc/iscan/vscan','vscan'], '-za -a {}', [0], qr/Found virus/, qr/Found virus (.+) in/ ], ### http://www.sald.com/, http://drweb.imshop.de/ - backs up DrWebD ['drweb - DrWeb Antivirus', ['/usr/local/drweb/drweb', '/opt/drweb/drweb', 'drweb'], '-path={} -al -go -ot -cn -upn -ok-', [0,32], [1,9,33], qr' infected (?:with|by)(?: virus)? (.*)$'], ['KasperskyLab kavscanner', ['/opt/kav/bin/kavscanner','kavscanner'], '-i1 -xp {}', [0,10,15], [5,20,21,25], qr/(?:CURED|INFECTED|CUREFAILED|WARNING|SUSPICION) (.*)/ , sub {chdir('/opt/kav/bin') or die "Can't chdir to kav: $!"}, sub {chdir($TEMPBASE) or die "Can't chdir back to $TEMPBASE $!"}, ], # Commented out because the name 'sweep' clashes with Debian and FreeBSD # package/port of an audio editor. Make sure the correct 'sweep' is found # in the path when enabling. # # ### http://www.sophos.com/ - backs up Sophie or SAVI-Perl # ['Sophos Anti Virus (sweep)', 'sweep', # '-nb -f -all -rec -ss -sc -archive -cab -tnef --no-reset-atime {}', # [0,2], qr/Virus .*? found/, # qr/^>>> Virus(?: fragment)? '?(.*?)'? found/, # ], # # other options to consider: -mime -oe -idedir=/usr/local/sav # always succeeds (uncomment to consider mail clean if all other scanners fail) # ['always-clean', sub {0}], ); 1; # insure a defined return
amavisd-new ist das Programm, das Postfix und SpamAssassin/ClamAV zusammenhält. Postfix leitet die Mails an amavisd-new weiter, was dann SpamAssassin und ClamAV aufruft, die E-Mails zu scannen. Sieh Dir bitte die Spamassassin und ClamAV Einstellungen in /etc/amavisd/amavisd.conf an. Selbstverständlich kannst Du diese Datei noch weiter anpassen. Sieh Dir dazu die Erklärungen in der originalen /etc/amavisd/amavisd.conf Datei an!
