Virtuelle Benutzer und Domains mit Postfix, Courier und MySQL (Mandriva 2008.0)
9 Installiere Amavisd-new, SpamAssassin und ClamAV
Um amavisd-new, spamassassin und clamav zu installieren, lass folgenden Befehl laufen:
urpmi amavisd-new spamassassin spamassassin-spamc spamassassin-spamd pax cabextract lha lzop ncompress nomarch clamd clamav unzip bzip2 arj freeze p7zip
Nun müssen wir /etc/amavisd/amavisd.conf bearbeiten.
vi /etc/amavisd/amavisd.conf
In dieser Datei ändern wir sechs Stellen:
1) Ändere
$inet_socket_port = 10025;   # listen on this local TCP port(s)
zu
$inet_socket_port = 10024;   # listen on this local TCP port(s)
2) Ändere
$sa_tag_level_deflt  = 1.0;  # add spam info headers if at, or above that level
$sa_tag2_level_deflt = 4.9;  # add 'spam detected' headers at that level
$sa_kill_level_deflt = 4.9;  # triggers spam evasive actions (e.g. blocks mail)
$sa_dsn_cutoff_level = 10;   # spam level beyond which a DSN is not sent
zu
$sa_tag_level_deflt  = 2.0;  # add spam info headers if at, or above that level
$sa_tag2_level_deflt = 4.0;  # add 'spam detected' headers at that level
$sa_kill_level_deflt = $sa_tag2_level_deflt;  # triggers spam evasive actions (e.g. blocks mail)
(Natürlich kannst Du die spam scores an Deine Wünsche anpassen.)
3) Ändere
# @lookup_sql_dsn =
#   ( ['DBI:mysql:database=mail;host=127.0.0.1;port=3306', 'user1', 'passwd1'],
#     ['DBI:mysql:database=mail;host=host2', 'username2', 'password2'],
#     ["DBI:SQLite:dbname=$MYHOME/sql/mail_prefs.sqlite", '', ''] );
# @storage_sql_dsn = @lookup_sql_dsn;  # none, same, or separate database
zu
# @lookup_sql_dsn =
@lookup_sql_dsn =
   ( ['DBI:mysql:database=mail;host=127.0.0.1;port=3306', 'mail_admin', 'mail_admin_password'] );
$sql_select_policy = 'SELECT "Y" as local FROM domains WHERE CONCAT("@",domain) IN (%k)';
$sql_select_white_black_list = undef;  # undef disables SQL white/blacklisting
$recipient_delimiter = '+';                # (default is '+')
$replace_existing_extension = 1;        # (default is false)
$localpart_is_case_sensitive = 0;        # (default is false)
(Vergewissere Dich, dass Du die richtigen Dantenbankangaben eingibst!)
4) Ändere
# $recipient_delimiter = '+';  # undef disables address extensions altogether
# when enabling addr extensions do also Postfix/main.cf: recipient_delimiter=+
zu
$recipient_delimiter = undef;  # undef disables address extensions altogether
5) Ändere
# $notify_method  = 'smtp:[127.0.0.1]:10026';
# $forward_method = 'smtp:[127.0.0.1]:10026';  # set to undef with milter!
zu
$notify_method  = 'smtp:[127.0.0.1]:10025';
$forward_method = 'smtp:[127.0.0.1]:10025';  # set to undef with milter!
6) Ändere
# $final_virus_destiny      = D_DISCARD;
# $final_banned_destiny     = D_BOUNCE;
# $final_spam_destiny       = D_PASS;
# $final_bad_header_destiny = D_PASS;
zu
$final_virus_destiny      = D_REJECT;
$final_banned_destiny     = D_REJECT;
(Natürlich ist es ganz Dir überlassen, wie Du mit Spam und Viren verfährst. Ich habe mich entschlossen, Spam zu akzeptieren (D_PASS) damit Spam in meinem E-Mail Klienten mit einem einfachen Filter Rule gefiltert werden kann (das hängt von dem ab, was von amavisd-new überschrieben wird, wenn es denkt, dass eine Mail Spam ist). Die zulässigen Aktionen (D_PASS, D_DISCARD, D_BOUNCE, and D_REJECT) sind hier beschrieben: http://www.ijs.si/software/amavisd/amavisd-new-docs.html#actions)
Nach meinen Änderungen sieht /etc/amavisd/amavisd.conf wie folgt aus:
use strict;
# a minimalistic configuration file for amavisd-new with all necessary settings
#   see amavisd.conf-default for a list of all variables with their defaults;
#   see amavisd.conf-sample for a traditional-style commented file;
#   for more details see documentation in INSTALL, README_FILES/*
#   and at http://www.ijs.si/software/amavisd/amavisd-new-docs.html
# COMMONLY ADJUSTED SETTINGS:
# @bypass_virus_checks_maps = (1);  # controls running of anti-virus code
# @bypass_spam_checks_maps  = (1);  # controls running of anti-spam code
# $bypass_decode_parts = 1;         # controls running of decoders&dearchivers
$max_servers = 2;            # num of pre-forked children (2..15 is common), -m
$daemon_user  = 'amavis';    # (no default;  customary: vscan or amavis), -u
$daemon_group = 'amavis';    # (no default;  customary: vscan or amavis), -g
$mydomain = 'localhost.localdomain';   # a convenient default for other settings
# $MYHOME = '/var/lib/amavis';   # a convenient default for other settings, -H
$TEMPBASE = "$MYHOME/tmp";   # working directory, needs to exist, -T
$ENV{TMPDIR} = $TEMPBASE;    # environment variable TMPDIR, used by SA, etc.
$QUARANTINEDIR = '/var/spool/amavis/virusmails';  # -Q
# $quarantine_subdir_levels = 1;  # add level of subdirs to disperse quarantine
# $daemon_chroot_dir = $MYHOME;   # chroot directory or undef, -R
# $db_home   = "$MYHOME/db";      # dir for bdb nanny/cache/snmp databases, -D
# $helpers_home = "$MYHOME/var";  # working directory for SpamAssassin, -S
# $lock_file = "$MYHOME/var/lib/amavisd.lock";  # -L
# $pid_file  = "$MYHOME/var/lib/amavisd.pid";   # -P
#NOTE: create directories $MYHOME/tmp, $MYHOME/var, $MYHOME/db manually
$log_level = 0;              # verbosity 0..5, -d
$log_recip_templ = undef;    # disable by-recipient level-0 log entries
$DO_SYSLOG = 1;              # log via syslogd (preferred)
$syslog_facility = 'mail';   # Syslog facility as a string
           # e.g.: mail, daemon, user, local0, ... local7
$syslog_priority = 'debug';  # Syslog base (minimal) priority as a string,
           # choose from: emerg, alert, crit, err, warning, notice, info, debug
$enable_db = 1;              # enable use of BerkeleyDB/libdb (SNMP and nanny)
$enable_global_cache = 1;    # enable use of libdb-based cache if $enable_db=1
$nanny_details_level = 2;    # nanny verbosity: 1: traditional, 2: detailed
@local_domains_maps = ( [".$mydomain"] );  # list of all local domains
@mynetworks = qw( 127.0.0.0/8 [::1] [FE80::]/10 [FEC0::]/10
                  10.0.0.0/8 172.16.0.0/12 192.168.0.0/16 );
$unix_socketname = "$MYHOME/amavisd.sock";  # amavisd-release or amavis-milter
               # option(s) -p overrides $inet_socket_port and $unix_socketname
# $inet_socket_port = [10024,10026];  # listen on multiple TCP ports
$policy_bank{'MYNETS'} = {   # mail originating from @mynetworks
  originating => 1,  # is true in MYNETS by default, but let's make it explicit
  os_fingerprint_method => undef,  # don't query p0f for internal clients
# it is up to MTA to re-route mail from authenticated roaming users or
# from internal hosts to a dedicated TCP port (such as 10026) for filtering
$interface_policy{'10026'} = 'ORIGINATING';
$policy_bank{'ORIGINATING'} = {  # mail supposedly originating from our users
  originating => 1,  # declare that mail was submitted by our smtp client
  allow_disclaimers => 1,  # enables disclaimer insertion if available
  # notify administrator of locally originating malware
  virus_admin_maps => ["[email protected]$mydomain"],
  spam_admin_maps  => ["[email protected]$mydomain"],
  warnbadhsender   => 1,
  # forward to a smtpd service providing DKIM signing service
  forward_method => 'smtp:[127.0.0.1]:10027',
  # force MTA conversion to 7-bit (e.g. before DKIM signing)
  smtpd_discard_ehlo_keywords => ['8BITMIME'],
  bypass_banned_checks_maps => [1],  # allow sending any file names and types
  terminate_dsn_on_notify_success => 0,  # don't remove NOTIFY=SUCCESS option
$interface_policy{'SOCK'} = 'AM.PDP-SOCK'; # only applies with $unix_socketname
# Use with amavis-release over a socket or with Petr Rehor's amavis-milter.c
# (with amavis-milter.c from this package or old amavis.c client use 'AM.CL'):
$policy_bank{'AM.PDP-SOCK'} = {
  protocol => 'AM.PDP',
  auth_required_release => 0,  # do not require secret_id for amavisd-release
#$sa_tag_level_deflt  = 1.0;  # add spam info headers if at, or above that level
#$sa_tag2_level_deflt = 4.9;  # add 'spam detected' headers at that level
#$sa_kill_level_deflt = 4.9;  # triggers spam evasive actions (e.g. blocks mail)
#$sa_dsn_cutoff_level = 10;   # spam level beyond which a DSN is not sent
# $sa_quarantine_cutoff_level = 25; # spam level beyond which quarantine is off
$penpals_bonus_score = 8;    # (no effect without a @storage_sql_dsn database)
$penpals_threshold_high = $sa_kill_level_deflt;  # don't waste time on hi spam
$sa_mail_body_size_limit = 400*1024; # don't waste time on SA if mail is larger
$sa_local_tests_only = 0;    # only tests which do not require internet access?
# @lookup_sql_dsn =
@lookup_sql_dsn =
# $timestamp_fmt_mysql = 1; # if using MySQL *and* msgs.time_iso is TIMESTAMP;
#   defaults to 0, which is good for non-MySQL or if msgs.time_iso is CHAR(16)
$virus_admin               = "[email protected]$mydomain";  # notifications recip.
$mailfrom_notify_admin     = "[email protected]$mydomain";  # notifications sender
$mailfrom_notify_recip     = "[email protected]$mydomain";  # notifications sender
$mailfrom_notify_spamadmin = "[email protected]$mydomain"; # notifications sender
$mailfrom_to_quarantine = ''; # null return path; uses original sender if undef
@addr_extension_virus_maps      = ('virus');
@addr_extension_banned_maps     = ('banned');
@addr_extension_spam_maps       = ('spam');
@addr_extension_bad_header_maps = ('badh');
$path = '/usr/local/sbin:/usr/local/bin:/usr/sbin:/sbin:/usr/bin:/bin';
# $dspam = 'dspam';
$MAXLEVELS = 14;
$MAXFILES = 1500;
$MIN_EXPANSION_QUOTA =      100*1024;  # bytes  (default undef, not enforced)
$MAX_EXPANSION_QUOTA = 300*1024*1024;  # bytes  (default undef, not enforced)
$sa_spam_subject_tag = '***SPAM*** ';
$defang_virus  = 1;  # MIME-wrap passed infected mail
$defang_banned = 1;  # MIME-wrap passed mail containing banned name
# for defanging bad headers only turn on certain minor contents categories:
$defang_by_ccat{+CC_BADH.",3"} = 1;  # NUL or CR character in header
$defang_by_ccat{+CC_BADH.",5"} = 1;  # header line longer than 998 characters
$defang_by_ccat{+CC_BADH.",6"} = 1;  # header field syntax error
# OTHER MORE COMMON SETTINGS (defaults may suffice):
# $myhostname = 'host.example.com';  # must be a fully-qualified domain name!
# $os_fingerprint_method = 'p0f:127.0.0.1:2345';  # to query p0f-analyzer.pl
## hierarchy by which a final setting is chosen:
##   policy bank (based on port or IP address) -> *_by_ccat
##   *_by_ccat (based on mail contents) -> *_maps
##   *_maps (based on recipient address) -> final configuration value
# SOME OTHER VARIABLES WORTH CONSIDERING (see amavisd.conf-default for all)
# $warnbadhsender,
# $warnvirusrecip, $warnbannedrecip, $warnbadhrecip, (or @warn*recip_maps)
# @bypass_virus_checks_maps, @bypass_spam_checks_maps,
# @bypass_banned_checks_maps, @bypass_header_checks_maps,
# @virus_lovers_maps, @spam_lovers_maps,
# @banned_files_lovers_maps, @bad_header_lovers_maps,
# @blacklist_sender_maps, @score_sender_maps,
# $clean_quarantine_method, $virus_quarantine_to, $banned_quarantine_to,
# $bad_header_quarantine_to, $spam_quarantine_to,
# $defang_bad_header, $defang_undecipherable, $defang_spam
# REMAINING IMPORTANT VARIABLES ARE LISTED HERE BECAUSE OF LONGER ASSIGNMENTS
@keep_decoded_original_maps = (new_RE(
# qr'^MAIL$',   # retain full original message for virus checking (can be slow)
  qr'^MAIL-UNDECIPHERABLE$', # recheck full mail if it contains undecipherables
  qr'^(ASCII(?! cpio)|text|uuencoded|xxencoded|binhex)'i,
# qr'^Zip archive data',     # don't trust Archive::Zip
# for $banned_namepath_re (a new-style of banned table) see amavisd.conf-sample
$banned_filename_re = new_RE(
### BLOCKED ANYWHERE
# qr'^UNDECIPHERABLE$',  # is or contains any undecipherable components
  qr'^.(exe-ms|dll)$',                   # banned file(1) types, rudimentary
# qr'^.(exe|lha|tnef|cab|dll)$',         # banned file(1) types
### BLOCK THE FOLLOWING, EXCEPT WITHIN UNIX ARCHIVES:
# [ qr'^.(gz|bz2)$'             => 0 ],  # allow any in gzip or bzip2
  [ qr'^.(rpm|cpio|tar)$'       => 0 ],  # allow any in Unix-type archives
  qr'..(pif|scr)$'i,                     # banned extensions - rudimentary
# qr'^.zip$',                            # block zip type
### BLOCK THE FOLLOWING, EXCEPT WITHIN ARCHIVES:
# [ qr'^.(zip|rar|arc|arj|zoo)$'=> 0 ],  # allow any within these archives
  qr'^application/x-msdownload$'i,        # block these MIME types
  qr'^application/x-msdos-program$'i,
  qr'^application/hta$'i,
# qr'^message/partial$'i,         # rfc2046 MIME type
# qr'^message/external-body$'i,   # rfc2046 MIME type
# qr'^(application/x-msmetafile|image/x-wmf)$'i,  # Windows Metafile MIME type
# qr'^.wmf$',                            # Windows Metafile file(1) type
  # block certain double extensions in filenames
  qr'.[^./]*[A-Za-z][^./]*.s*(exe|vbs|pif|scr|bat|cmd|com|cpl|dll)[.s]*$'i,
# qr'{[0-9a-f]{8}(-[0-9a-f]{4}){3}-[0-9a-f]{12}}?'i, # Class ID CLSID, strict
# qr'{[0-9a-z]{4,}(-[0-9a-z]{4,}){0,7}}?'i, # Class ID extension CLSID, loose
  qr'..(exe|vbs|pif|scr|cpl)$'i,             # banned extension - basic
# qr'..(exe|vbs|pif|scr|cpl|bat|cmd|com)$'i, # banned extension - basic+cmd
# qr'..(ade|adp|app|bas|bat|chm|cmd|com|cpl|crt|emf|exe|fxp|grp|hlp|hta|
#        inf|ins|isp|js|jse|lnk|mda|mdb|mde|mdw|mdt|mdz|msc|msi|msp|mst|
#        ops|pcd|pif|prg|reg|scr|sct|shb|shs|vb|vbe|vbs|
#        wmf|wsc|wsf|wsh)$'ix,  # banned ext - long
# qr'..(ani|cur|ico)$'i,                 # banned cursors and icons filename
# qr'^.ani$',                            # banned animated cursor file(1) type
# qr'..(mim|b64|bhx|hqx|xxe|uu|uue)$'i,  # banned extension - WinZip vulnerab.
# See http://support.microsoft.com/default.aspx?scid=kb;EN-US;q262631
# and http://www.cknow.com/vtutor/vtextensions.htm
# ENVELOPE SENDER SOFT-WHITELISTING / SOFT-BLACKLISTING
@score_sender_maps = ({ # a by-recipient hash lookup table,
                        # results from all matching recipient tables are summed
# ## per-recipient personal tables  (NOTE: positive: black, negative: white)
# '[email protected]'  => [{'[email protected]' => 10.0}],
# '[email protected]'  => [{'.ebay.com'                 => -3.0}],
# '[email protected]'  => [{'[email protected]' => -7.0,
#                           '.cleargreen.com'           => -5.0}],
  ## site-wide opinions about senders (the '.' matches any recipient)
  '.' => [  # the _first_ matching sender determines the score boost
   new_RE(  # regexp-type lookup table, just happens to be all soft-blacklist
    [qr'^(bulkmail|offers|cheapbenefits|earnmoney|foryou)@'i         => 5.0],
    [qr'^(greatcasino|investments|lose_weight_today|market.alert)@'i=> 5.0],
    [qr'^(money2you|MyGreenCard|new.tld.registry|opt-out|opt-in)@'i=> 5.0],
    [qr'^(optin|saveonlsmoking2002k|specialoffer|specialoffers)@'i   => 5.0],
    [qr'^(stockalert|stopsnoring|wantsome|workathome|yesitsfree)@'i  => 5.0],
    [qr'^(your_friend|greatoffers)@'i                                => 5.0],
    [qr'^(inkjetplanet|marketopt|MakeMoney)d*@'i                    => 5.0],
#  read_hash("/var/lib/amavis/sender_scores_sitewide"),
   { # a hash-type lookup table (associative array)
     '[email protected]'                        => -3.0,
     'securityfocus.com'                      => -3.0,
     '[email protected]'=> -3.0,
     'spamassassin.apache.org'                => -3.0,
     '[email protected]'                => -5.0,
     'returns.groups.yahoo.com'               => -3.0,
     lc('[email protected]')    => -3.0,
     lc('[email protected]') => -5.0,
     # soft-blacklisting (positive score)
     '[email protected]'                     =>  3.0,
     '.example.net'                           =>  1.0,
  ],  # end of site-wide tables
@decoders = (
  ['mail', &do_mime_decode],
  ['asc',  &do_ascii],
  ['uue',  &do_ascii],
  ['hqx',  &do_ascii],
  ['ync',  &do_ascii],
  ['F',    &do_uncompress, ['unfreeze','freeze -d','melt','fcat'] ],
  ['Z',    &do_uncompress, ['uncompress','gzip -d','zcat'] ],
  ['gz',   &do_uncompress,  'gzip -d'],
  ['gz',   &do_gunzip],
  ['bz2',  &do_uncompress,  'bzip2 -d'],
  ['lzo',  &do_uncompress,  'lzop -d'],
  ['rpm',  &do_uncompress, ['rpm2cpio.pl','rpm2cpio'] ],
  ['cpio', &do_pax_cpio,   ['pax','gcpio','cpio'] ],
  ['tar',  &do_pax_cpio,   ['pax','gcpio','cpio'] ],
  ['deb',  &do_ar,          'ar'],
# ['a',    &do_ar,          'ar'],  # unpacking .a seems an overkill
  ['zip',  &do_unzip],
  ['7z',   &do_7zip,       ['7zr','7za','7z'] ],
  ['rar',  &do_unrar,      ['rar','unrar'] ],
  ['arj',  &do_unarj,      ['arj','unarj'] ],
  ['arc',  &do_arc,        ['nomarch','arc'] ],
  ['zoo',  &do_zoo,        ['zoo','unzoo'] ],
  ['lha',  &do_lha,         'lha'],
# ['doc',  &do_ole,         'ripole'],
  ['cab',  &do_cabextract,  'cabextract'],
  ['tnef', &do_tnef_ext,    'tnef'],
  ['tnef', &do_tnef],
# ['sit',  &do_unstuff,     'unstuff'],  # broken/unsafe decoder
  ['exe',  &do_executable, ['rar','unrar'], 'lha', ['arj','unarj'] ],
@av_scanners = (
# ### http://www.clanfield.info/sophie/ (http://www.vanja.com/tools/sophie/)
# ['Sophie',
#   &ask_daemon, ["{}/n", '/var/run/sophie'],
#   qr/(?x)^ 0+ ( : | [?00rn]* $)/,  qr/(?x)^ 1 ( : | [?00rn]* $)/,
#   qr/(?x)^ [-+]? d+ : (.*?) [?00rn]* $/ ],
# ### http://www.csupomona.edu/~henson/www/projects/SAVI-Perl/
# ['Sophos SAVI', &sophos_savi ],
# ### http://www.clamav.net/
['ClamAV-clamd',
  &ask_daemon, ["CONTSCAN {}n", "/var/lib/clamav/clamd.socket"],
  qr/bOK$/, qr/bFOUND$/,
  qr/^.*?: (?!Infected Archive)(.*) FOUND$/ ],
# NOTE: run clamd under the same user as amavisd, or run it under its own
#   uid such as clamav, add user clamav to the amavis group, and then add
#   AllowSupplementaryGroups to clamd.conf;
# NOTE: match socket name (LocalSocket) in clamav.conf to the socket name in
#   this entry; when running chrooted one may prefer socket "$MYHOME/clamd".
# ### http://www.clamav.net/ and CPAN  (memory-hungry! clamd is preferred)
# # note that Mail::ClamAV requires perl to be build with threading!
# ['Mail::ClamAV', &ask_clamav, "*", [0], [1], qr/^INFECTED: (.+)/],
# ### http://www.openantivirus.org/
# ['OpenAntiVirus ScannerDaemon (OAV)',
#   &ask_daemon, ["SCAN {}n", '127.0.0.1:8127'],
#   qr/^OK/, qr/^FOUND: /, qr/^FOUND: (.+)/ ],
# ### http://www.vanja.com/tools/trophie/
# ['Trophie',
#   &ask_daemon, ["{}/n", '/var/run/trophie'],
# ### http://www.grisoft.com/
# ['AVG Anti-Virus',
#   &ask_daemon, ["SCAN {}n", '127.0.0.1:55555'],
#   qr/^200/, qr/^403/, qr/^403 .*?: ([^rn]+)/ ],
# ### http://www.f-prot.com/
# ['FRISK F-Prot Daemon',
#   &ask_daemon,
#   ["GET {}/*?-dumb%20-archive%20-packed HTTP/1.0rnrn",
#     ['127.0.0.1:10200','127.0.0.1:10201','127.0.0.1:10202',
#      '127.0.0.1:10203','127.0.0.1:10204'] ],
#   qr/(?i)<summary[^>]*>clean</summary>/,
#   qr/(?i)<summary[^>]*>infected</summary>/,
#   qr/(?i)<name>(.+)</name>/ ],
# ### http://www.sald.com/, http://www.dials.ru/english/, http://www.drweb.ru/
# ['DrWebD', &ask_daemon,   # DrWebD 4.31 or later
#   [pack('N',1).  # DRWEBD_SCAN_CMD
#    pack('N',0x00280001).   # DONT_CHANGEMAIL, IS_MAIL, RETURN_VIRUSES
#    pack('N',     # path length
#      length("$TEMPBASE/amavis-yyyymmddTHHMMSS-xxxxx/parts/pxxx")).
#    '{}/*'.       # path
#    pack('N',0).  # content size
#    pack('N',0),
#    '/var/drweb/run/drwebd.sock',
#  # '/var/lib/amavis/var/run/drwebd.sock',   # suitable for chroot
#  # '/usr/local/drweb/run/drwebd.sock',  # FreeBSD drweb ports default
#  # '127.0.0.1:3000',                    # or over an inet socket
#   qr/Ax00[x10x11][x00x10]x00/s,         # IS_CLEAN,EVAL_KEY; SKIPPED
#   qr/Ax00[x00x01][x00x10][x20x40x80]/s, # KNOWN_V,UNKNOWN_V,V._MODIF
#   qr/A.{12}(?:infected with )?([^x00]+)x00/s,
# # NOTE: If using amavis-milter, change length to:
# # length("$TEMPBASE/amavis-milter-xxxxxxxxxxxxxx/parts/pxxx").
  ### http://www.kaspersky.com/  (kav4mailservers)
  ['KasperskyLab AVP - aveclient',
    ['/usr/local/kav/bin/aveclient','/usr/local/share/kav/bin/aveclient',
     '/opt/kav/5.5/kav4mailservers/bin/aveclient','aveclient'],
    '-p /var/run/aveserver -s {}/*',
    [0,3,6,8], qr/b(INFECTED|SUSPICION|SUSPICIOUS)b/,
    qr/(?:INFECTED|WARNING|SUSPICION|SUSPICIOUS) (.+)/,
  # NOTE: one may prefer [0],[2,3,4,5], depending on how suspicious,
  # currupted or protected archives are to be handled
  ['KasperskyLab AntiViral Toolkit Pro (AVP)', ['avp'],
    '-* -P -B -Y -O- {}', [0,3,6,8], [2,4],    # any use for -A -K   ?
    qr/infected: (.+)/,
    sub {chdir('/opt/AVP') or die "Can't chdir to AVP: $!"},
    sub {chdir($TEMPBASE) or die "Can't chdir back to $TEMPBASE $!"},
  ### The kavdaemon and AVPDaemonClient have been removed from Kasperky
  ### products and replaced by aveserver and aveclient
  ['KasperskyLab AVPDaemonClient',
    [ '/opt/AVP/kavdaemon',       'kavdaemon',
      '/opt/AVP/AvpDaemonClient', 'AvpDaemonClient',
      '/opt/AVP/AvpTeamDream',    'AvpTeamDream',
      '/opt/AVP/avpdc', 'avpdc' ],
    "-f=$TEMPBASE {}", [0,8], [3,4,5,6], qr/infected: ([^rn]+)/ ],
    # change the startup-script in /etc/init.d/kavd to:
    #   DPARMS="-* -Y -dl -f=/var/lib/amavis /var/lib/amavis"
    #   (or perhaps:   DPARMS="-I0 -Y -* /var/lib/amavis" )
    # adjusting /var/lib/amavis above to match your $TEMPBASE.
    # The '-f=/var/lib/amavis' is needed if not running it as root, so it
    # can find, read, and write its pid file, etc., see 'man kavdaemon'.
    # defUnix.prf: there must be an entry "*/var/lib/amavis" (or whatever
    #   directory $TEMPBASE specifies) in the 'Names=' section.
    # cd /opt/AVP/DaemonClients; configure; cd Sample; make
    # cp AvpDaemonClient /opt/AVP/
    # su - vscan -c "${PREFIX}/kavdaemon ${DPARMS}"
  ### http://www.centralcommand.com/
  ['CentralCommand Vexira (new) vascan',
    ['vascan','/usr/lib/Vexira/vascan'],
    "-a s --timeout=60 --temp=$TEMPBASE -y $QUARANTINEDIR ".
    "--log=/var/log/vascan.log {}",
    [0,3], [1,2,5],
    qr/(?x)^s* (?:virus|iworm|macro|mutant|sequence|trojan) found: ( [^]s']+ ) ... / ],
    # Adjust the path of the binary and the virus database as needed.
    # 'vascan' does not allow to have the temp directory to be the same as
    # the quarantine directory, and the quarantine option can not be disabled.
    # If $QUARANTINEDIR is not used, then another directory must be specified
    # to appease 'vascan'. Move status 3 to the second list if password
    # protected files are to be considered infected.
  ### http://www.avira.com/
  ### Avira AntiVir (formerly H+BEDV) or (old) CentralCommand Vexira Antivirus
  ['Avira AntiVir', ['antivir','vexira'],
    '--allfiles -noboot -nombr -rs -s -z {}', [0], qr/ALERT:|VIRUS:/,
    qr/(?x)^s* (?: ALERT: s* (?: [ | [^']* ' ) |
         (?i) VIRUS: .*? virus '?) ( [^]s']+ )/ ],
    # NOTE: if you only have a demo version, remove -z and add 214, as in:
    #  '--allfiles -noboot -nombr -rs -s {}', [0,214], qr/ALERT:|VIRUS:/,
  ### http://www.commandsoftware.com/
  ['Command AntiVirus for Linux', 'csav',
    '-all -archive -packed {}', [50], [51,52,53],
    qr/Infection: (.+)/ ],
  ### http://www.symantec.com/
  ['Symantec CarrierScan via Symantec CommandLineScanner',
    'cscmdline', '-a scan -i 1 -v -s 127.0.0.1:7777 {}',
    qr/^Files Infected:s+0$/, qr/^Infectedb/,
    qr/^(?:Info|Virus Name):s+(.+)/ ],
  ['Symantec AntiVirus Scan Engine',
    'savsecls', '-server 127.0.0.1:7777 -mode scanrepair -details -verbose {}',
    [0], qr/^Infectedb/,
    # NOTE: check options and patterns to see which entry better applies
# ### http://www.f-secure.com/products/anti-virus/  version 4.65
#  ['F-Secure Antivirus for Linux servers',
#   ['/opt/f-secure/fsav/bin/fsav', 'fsav'],
#   '--delete=no --disinf=no --rename=no --archive=yes --auto=yes '.
#   '--dumb=yes --list=no --mime=yes {}', [0], [3,6,8],
#   qr/(?:infection|Infected|Suspected): (.+)/ ],
  ### http://www.f-secure.com/products/anti-virus/  version 5.52
    '--virus-action1=report --archive=yes --auto=yes '.
    '--dumb=yes --list=no --mime=yes {}', [0], [3,4,6,8],
    qr/(?:infection|Infected|Suspected|Riskware): (.+)/ ],
    # NOTE: internal archive handling may be switched off by '--archive=no'
    #   to prevent fsav from exiting with status 9 on broken archives
# ### http://www.avast.com/
# ['avast! Antivirus daemon',
#   &ask_daemon,        # greets with 220, terminate with QUIT
#   ["SCAN {}?15?12QUIT?15?12", '/var/run/avast4/mailscanner.sock'],
#   qr/t[+]/, qr/t[L]t/, qr/t[L]t([^[ t?15?12]+)/ ],
# ['avast! Antivirus - Client/Server Version', 'avastlite',
#   '-a /var/run/avast4/mailscanner.sock -n {}', [0], [1],
#   qr/t[L]t([^[ t?15?12]+)/ ],
  ['CAI InoculateIT', 'inocucmd',  # retired product
    '-sec -nex {}', [0], [100],
    qr/was infected by virus (.+)/ ],
  # see: http://www.flatmtn.com/computer/Linux-Antivirus_CAI.html
  ### http://www3.ca.com/Solutions/Product.asp?ID=156  (ex InoculateIT)
  ['CAI eTrust Antivirus', 'etrust-wrapper',
    '-arc -nex -spm h {}', [0], [101],
    qr/is infected by virus: (.+)/ ],
    # NOTE: requires suid wrapper around inocmd32; consider flag: -mod reviewer
    # see http://marc.theaimsgroup.com/?l=amavis-user&m=109229779912783
  ### http://mks.com.pl/english.html
  ['MkS_Vir for Linux (beta)', ['mks32','mks'],
    '-s {}/*', [0], [1,2],
    qr/--[ t]*(.+)/ ],
  ['MkS_Vir daemon', 'mksscan',
    '-s -q {}', [0], [1..7],
    qr/^... (S+)/ ],
# ### http://www.nod32.com/,  version v2.52 and above
# ['ESET NOD32 for Linux Mail servers',
#   ['/opt/eset/nod32/bin/nod32cli', 'nod32cli'],
#    '--subdir --files -z --sfx --rtp --adware --unsafe --pattern --heur '.
#    '-w -a --action-on-infected=accept --action-on-uncleanable=accept '.
#    '--action-on-notscanned=accept {}',
#   [0,3], [1,2], qr/virus="([^"]+)"/ ],
  ### http://www.eset.com/, version v2.7
  ['ESET NOD32 Linux Mail Server - command line interface',
    ['/usr/bin/nod32cli', '/opt/eset/nod32/bin/nod32cli', 'nod32cli'],
    '--subdir {}', [0,3], [1,2], qr/virus="([^"]+)"/ ],
  ## http://www.nod32.com/,  NOD32LFS version 2.5 and above
  ['ESET NOD32 for Linux File servers',
    ['/opt/eset/nod32/sbin/nod32','nod32'],
    '--files -z --mail --sfx --rtp --adware --unsafe --pattern --heur '.
    '-w -a --action=1 -b {}',
    [0], [1,10], qr/^object=.*, virus="(.*?)",/ ],
# Experimental, based on posting from Rado Dibarbora (Dibo) on 2002-05-31
# ['ESET Software NOD32 Client/Server (NOD32SS)',
#   &ask_daemon2,    # greets with 200, persistent, terminate with QUIT
#   ["SCAN {}/*rn", '127.0.0.1:8448' ],
#   qr/^200 File OK/, qr/^201 /, qr/^201 (.+)/ ],
  ### http://www.norman.com/products_nvc.shtml
  ['Norman Virus Control v5 / Linux', 'nvcc',
    '-c -l:0 -s -u -temp:$TEMPBASE {}', [0,10,11], [1,2,14],
    qr/(?i).* virus in .* -> '(.+)'/ ],
  ### http://www.pandasoftware.com/
  ['Panda CommandLineSecure 9 for Linux',
    ['/opt/pavcl/usr/bin/pavcl','pavcl'],
    '-auto -aex -heu -cmp -nbr -nor -nos -eng -nob {}',
    qr/Number of files infected[ .]*: 0+(?!d)/,
    qr/Number of files infected[ .]*: 0*[1-9]/,
    qr/Found virus :s*(S+)/ ],
  # NOTE: for efficiency, start the Panda in resident mode with 'pavcl -tsr'
  # before starting amavisd - the bases are then loaded only once at startup.
  # To reload bases in a signature update script:
  #   /opt/pavcl/usr/bin/pavcl -tsr -ulr; /opt/pavcl/usr/bin/pavcl -tsr
  # Please review other options of pavcl, for example:
  #  -nomalw, -nojoke, -nodial, -nohackt, -nospyw, -nocookies
# ### http://www.pandasoftware.com/
# ['Panda Antivirus for Linux', ['pavcl'],
#   '-TSR -aut -aex -heu -cmp -nbr -nor -nso -eng {}',
#   [0], [0x10, 0x30, 0x50, 0x70, 0x90, 0xB0, 0xD0, 0xF0],
#   qr/Found virus :s*(S+)/ ],
# GeCAD AV technology is acquired by Microsoft; RAV has been discontinued.
# Check your RAV license terms before fiddling with the following two lines!
# ['GeCAD RAV AntiVirus 8', 'ravav',
#   '--all --archive --mail {}', [1], [2,3,4,5], qr/Infected: (.+)/ ],
# # NOTE: the command line switches changed with scan engine 8.5 !
# # (btw, assigning stdin to /dev/null causes RAV to fail)
  ### http://www.nai.com/
  ['NAI McAfee AntiVirus (uvscan)', 'uvscan',
    '--secure -rv --mime --summary --noboot - {}', [0], [13],
    qr/(?x) Found (?:
         the (.+) (?:virus|trojan)  |
         (?:virus|trojan) or variant ([^ ]+)  |
        : (.+) NOT a virus)/,
  # sub {$ENV{LD_PRELOAD}='/lib/libc.so.6'},
  # sub {delete $ENV{LD_PRELOAD}},
  # NOTE1: with RH9: force the dynamic linker to look at /lib/libc.so.6 before
  # anything else by setting environment variable LD_PRELOAD=/lib/libc.so.6
  # and then clear it when finished to avoid confusing anything else.
  # NOTE2: to treat encrypted files as viruses replace the [13] with:
  #  qr/^s{5,}(Found|is password-protected|.*(virus|trojan))/
  ### http://www.virusbuster.hu/en/
  ['VirusBuster', ['vbuster', 'vbengcl'],
    "{} -ss -i '*' -log=$MYHOME/vbuster.log", [0], [1],
    qr/: '(.*)' - Virus/ ],
  # VirusBuster Ltd. does not support the daemon version for the workstation
  # engine (vbuster-eng-1.12-linux-i386-libc6.tgz) any longer. The names of
  # binaries, some parameters AND return codes have changed (from 3 to 1).
  # See also the new Vexira entry 'vascan' which is possibly related.
# ### http://www.virusbuster.hu/en/
# ['VirusBuster (Client + Daemon)', 'vbengd',
#   '-f -log scandir {}', [0], [3],
#   qr/Virus found = (.*);/ ],
# # HINT: for an infected file it always returns 3,
# # although the man-page tells a different story
  ### http://www.cyber.com/
  ['CyberSoft VFind', 'vfind',
    '--vexit {}/*', [0], [23], qr/##==>>>> VIRUS ID: CVDL (.+)/,
  # sub {$ENV{VSTK_HOME}='/usr/lib/vstk'},
  ['avast! Antivirus', ['/usr/bin/avastcmd','avastcmd'],
    '-a -i -n -t=A {}', [0], [1], qr/binfected by:s+([^ tn[]]+)/ ],
  ### http://www.ikarus-software.com/
  ['Ikarus AntiVirus for Linux', 'ikarus',
    '{}', [0], [40], qr/Signature (.+) found/ ],
  ### http://www.bitdefender.com/
  ['BitDefender', 'bdc',
    '--arc --mail {}', qr/^Infected files *:0+(?!d)/,
    qr/^(?:Infected files|Identified viruses|Suspect files) *:0*[1-9]/,
    qr/(?:suspected|infected): (.*)(?:?33|$)/ ],
  # consider also: --all --nowarn --alev=15 --flev=15.  The --all argument may
  # not apply to your version of bdc, check documentation and see 'bdc --help'
  ### ArcaVir for Linux and Unix http://www.arcabit.pl/
  ['ArcaVir for Linux', ['arcacmd','arcacmd.static'],
    '-v 1 -summary 0 -s {}', [0], [1,2],
    qr/(?:VIR|WIR):[ t]*(.+)/ ],
# ['File::Scan', sub {Amavis::AV::ask_av(sub{
#   use File::Scan; my($fn)[email protected]_;
#   my($f)=File::Scan->new(max_txt_size=>0, max_bin_size=>0);
#   my($vname) = $f->scan($fn);
#   $f->error ? (2,"Error: ".$f->error)
#   : ($vname ne '') ? (1,"$vname FOUND") : (0,"Clean")}, @_) },
#   ["{}/*"], [0], [1], qr/^(.*) FOUND$/ ],
# ### fully-fledged checker for JPEG marker segments of invalid length
# ['check-jpeg',
#   sub { use JpegTester (); Amavis::AV::ask_av(&JpegTester::test_jpeg, @_) },
#   ["{}/*"], undef, [1], qr/^(bad jpeg: .*)$/ ],
# # NOTE: place file JpegTester.pm somewhere where Perl can find it,
# #       for example in /usr/local/lib/perl5/site_perl
@av_scanners_backup = (
  ### http://www.clamav.net/   - backs up clamd or Mail::ClamAV
  ['ClamAV-clamscan', 'clamscan',
    "--stdout --no-summary -r --tempdir=$TEMPBASE {}",
    [0], qr/:.*sFOUND$/, qr/^.*?: (?!Infected Archive)(.*) FOUND$/ ],
  ### http://www.f-prot.com/   - backs up F-Prot Daemon
  ['FRISK F-Prot Antivirus', ['f-prot','f-prot.sh'],
    '-dumb -archive -packed {}', [0,8], [3,6],   # or: [0], [3,6,8],
    qr/(?:Infection:|security risk named) (.+)|s+containss+(.+)$/ ],
  ### http://www.trendmicro.com/   - backs up Trophie
  ['Trend Micro FileScanner', ['/etc/iscan/vscan','vscan'],
    '-za -a {}', [0], qr/Found virus/, qr/Found virus (.+) in/ ],
  ### http://www.sald.com/, http://drweb.imshop.de/   - backs up DrWebD
  ['drweb - DrWeb Antivirus',  # security LHA hole in Dr.Web 4.33 and earlier
    ['/usr/local/drweb/drweb', '/opt/drweb/drweb', 'drweb'],
    '-path={} -al -go -ot -cn -upn -ok-',
    [0,32], [1,9,33], qr' infected (?:with|by)(?: virus)? (.*)$'],
   ['Kaspersky Antivirus v5.5',
     ['/opt/kaspersky/kav4fs/bin/kav4fs-kavscanner',
      '/opt/kav/5.5/kav4unix/bin/kavscanner',
      '/opt/kav/5.5/kav4mailservers/bin/kavscanner', 'kavscanner'],
     '-i0 -xn -xp -mn -R -ePASBME {}/*', [0,10,15], [5,20,21,25],
     qr/(?:INFECTED|WARNING|SUSPICION|SUSPICIOUS) (.*)/ ,
#    sub {chdir('/opt/kav/bin') or die "Can't chdir to kav: $!"},
#    sub {chdir($TEMPBASE) or die "Can't chdir back to $TEMPBASE $!"},
# Commented out because the name 'sweep' clashes with Debian and FreeBSD
# package/port of an audio editor. Make sure the correct 'sweep' is found
# in the path when enabling.
# ### http://www.sophos.com/   - backs up Sophie or SAVI-Perl
# ['Sophos Anti Virus (sweep)', 'sweep',
#   '-nb -f -all -rec -ss -sc -archive -cab -mime -oe -tnef '.
#   '--no-reset-atime {}',
#   [0,2], qr/Virus .*? found/,
#   qr/^>>> Virus(?: fragment)? '?(.*?)'? found/,
# # other options to consider: -idedir=/usr/local/sav
# always succeeds (uncomment to consider mail clean if all other scanners fail)
# ['always-clean', sub {0}],
1;  # insure a defined return
amavisd-new ist das Programm, das Postfix und SpamAssassin/ClamAV zusammenfügt. Postfix leitet die Mails an amavisd-new weiter, was dann SpamAssassin und ClamAV aufruft, die Mails zu scannen. Sieh Dir bitte die Einstellungen für Spamassassin und ClamAV in /etc/amavisd/amavisd.conf an. Selbstverständlich kannst Du diese Datei noch weiter anpassen. Sieh Dir dazu die Erklärungen in der originalen /etc/amavisd/amavisd.conf Datei an!
