Wie man den Internet Explorer auf Ubuntu (Feisty Fawn, Edgy Eft und Dapper Drake) installiert
Dir werden ein paar Fragen gestellt:
Welcome, falko! I’m IEs4Linux.
I can install IE 6, 5.5 and 5.0 for you easily and quickly.
You are just four ‚enter’s away from your IEs.
I’ll ask you some questions now. Just answer y or n (default answer is the bold one)
IE 6 will be installed automatically.
Do you want to install IE 5.5 SP2 too? [ y / n ] <– y
And do you want to install IE 5.01 SP2? [ y / n ] <– y
IEs can be installed using one of the following locales:
EN-US PT-BR DE FR ES IT NL SV JA KO NO
DA CN TW FI PL HU AR HE CS PT RU EL TR
Default is EN-US. Hit enter to keep it or choose a different one: <– [Specify your preferred locale or hit ENTER to use EN-US.]
By default, I will install everything at /home/falko/.ies4linux
I will also install Flash 9 plugin and create Desktop shortcuts.
Is that ok for you? (To configure advanced options type n) [ y / n ] <– y
Als Nächstes werden ein paar Dateien runter geladen und die drei Versionen des Internet Explorers werden installiert:
Installing IE 6
Initializing
Creating Wine Prefix
Extracting CAB files
Processing inf file
Installing IE 6
Installing TTF Fonts
Installing RICHED20
Installing ActiveX MFC40
Installing DCOM98
Installing registry
Finalizing
[ OK ]
Installing Flash Player 9
Extracting files
Installing flash on ie6
[ OK ]
Installing IE 5.5
Copying ie6 installation
Extracting files
Installing registry
Finalizing
[ OK ]
Installing IE 5.0
Extracting files
Installing registry
Finalizing
[ OK ]
IEs 4 Linux installations finished!
To run your IEs, type:
/home/falko/bin/ie6
/home/falko/bin/ie55
/home/falko/bin/ie5
If you have 5 minutes, help me translating IEs4Linux to your language.
Visit: http://tatanka.com.br/ies4linux/forum/viewtopic.php?p=2
Das war’s schon.
5 Testen
Schließe nun das Terminalfenster. Auf Deinem Desktop solltest Du nun drei Internet Explorer Symbole sehen:
Öffne nun jeden (eine Testseite von www.tatanka.com.br wird geladen):
und in jedem Explorer zu Help -> About Internet Explorer um die Version zu überprüfen. Die Versionen 6.0, 5.5 und 5.0 müssten installiert sein:
Internet Explorer 6.0:
Internet Explorer 5.5:
Internet Explorer 5.0:
6 Links
