SebastianHamm
Habe das Problem, das bei meinem vServer die E-Mailweiterleitung nicht funktioniert.
Im E-Mail Protokoll steht dies:
Habt Ihr einen TIpp für mich?
Queue ID- --Size-- ----Arrival Time---- -Sender/Recipient-------
B9B67180A6BC 1648 Wed Nov 30 09:29:49 xxxx@web.de
(connect to 127.0.0.1[127.0.0.1]:10024: Connection refused)
info@xxxx.de
B2718180A68D 1658 Wed Nov 30 09:14:57 xxxx@web.de
info@xxxx.de
Nov 30 12:38:41 vps10011 postfix/qmgr[1540]: B9B67180A6BC: from=<xxxx@web.de>, size=1648, nrcpt=1 (queue active)
Nov 30 12:38:41 vps10011 postfix/qmgr[1540]: 04238180A3EA: from=<bounce-HP2v2000001589b4884a4c3ddd5f4bbe5be50158@mail.paypal.de>, size=42933, nrcpt=1 (queue active)
Nov 30 12:38:41 vps10011 postfix/qmgr[1540]: DB451180A694: from=<n01310a6ac1-0c934921f07c43a9af2bff44a3f7bea5-info===xxxxxxxx.de@bounce.twitter.com>, size=104597, nrcpt=1 (queue active)
Nov 30 12:38:41 vps10011 postfix/qmgr[1540]: D8F9B180A6AD: from=<yjsedvx@infinitory.biz.ua>, size=182967, nrcpt=1 (queue active)
Nov 30 12:38:41 vps10011 postfix/smtp[1817]: connect to 127.0.0.1[127.0.0.1]:10024: Connection refused
Nov 30 12:38:41 vps10011 postfix/smtp[1818]: connect to 127.0.0.1[127.0.0.1]:10024: Connection refused
Nov 30 12:38:41 vps10011 postfix/smtp[1818]: 04238180A3EA: to=<info@xxxxxx.de>, relay=none, delay=424748, delays=424748/0.04/0/0, dsn=4.4.1, status=deferred (connect to 127.0.0.1[127.0.0.1]:10024: Connection refused)
Nov 30 12:38:41 vps10011 postfix/smtp[1817]: B9B67180A6BC: to=<info@xxxxxx.de>, relay=none, delay=532, delays=532/0.02/0/0, dsn=4.4.1, status=deferred (connect to 127.0.0.1[127.0.0.1]:10024: Connection refused)
Nov 30 12:38:41 vps10011 postfix/smtp[1818]: DB451180A694: to=<info@xxxxxx.de>, relay=none, delay=332441, delays=332441/0.07/0.01/0, dsn=4.4.1, status=deferred (connect to 127.0.0.1[127.0.0.1]:10024: Connection refused)
Nov 30 12:38:41 vps10011 postfix/smtp[1817]: D8F9B180A6AD: to=<info@xxxxxx.de>, relay=none, delay=25590, delays=25590/0.3/0/0, dsn=4.4.1, status=deferred (connect to 127.0.0.1[127.0.0.1]:10024: Connection refused)
Nov 30 12:40:02 vps10011 dovecot: imap-login: Disconnected (disconnected before auth was ready, waited 0 secs): user=<>, rip=::1, lip=::1, secured, session=<a/E4fYFCYI4AAAAAAAAAAAAAAAAAAAAB>
Nov 30 12:40:02 vps10011 postfix/smtpd[1979]: connect from localhost[::1]
Nov 30 12:40:02 vps10011 dovecot: pop3-login: Disconnected (no auth attempts in 0 secs): user=<>, rip=::1, lip=::1, secured, session=<8UM5fYFC+ZkAAAAAAAAAAAAAAAAAAAAB>
Nov 30 12:40:02 vps10011 postfix/smtpd[1979]: lost connection after CONNECT from localhost[::1]
Nov 30 12:40:02 vps10011 postfix/smtpd[1979]: disconnect from localhost[::1] commands=0/0
Nov 30 12:42:02 vps10011 postfix/scache[1821]: statistics: start interval Nov 30 12:38:41
Nov 30 12:42:02 vps10011 postfix/scache[1821]: statistics: domain lookup hits=0 miss=2 success=0%
Nov 30 12:43:40 vps10011 postfix[2112]: Postfix is running with backwards-compatible default settings
Nov 30 12:43:40 vps10011 postfix[2112]: See http://www.postfix.org/COMPATIBILITY_README.html for details
Nov 30 12:43:40 vps10011 postfix[2112]: To disable backwards compatibility use "postconf compatibility_level=2" and "postfix reload"
Nov 30 12:43:40 vps10011 postfix/master[1538]: terminating on signal 15
Nov 30 12:43:41 vps10011 postfix[2205]: Postfix is running with backwards-compatible default settings
Nov 30 12:43:41 vps10011 postfix[2205]: See http://www.postfix.org/COMPATIBILITY_README.html for details
Nov 30 12:43:41 vps10011 postfix[2205]: To disable backwards compatibility use "postconf compatibility_level=2" and "postfix reload"
Nov 30 12:43:42 vps10011 postfix/master[2242]: warning: /etc/postfix/master.cf: logical line must not start with whitespace: " -o syslog_name=postfix/submi..."
Nov 30 12:43:42 vps10011 postfix/master[2242]: /etc/postfix/master.cf: line 130: using backwards-compatible default setting chroot=y
Nov 30 12:43:42 vps10011 postfix/master[2242]: daemon started -- version 3.1.0, configuration /etc/postfix
