Nach update kein Mailversand mehr möglich mit STARTTLS / SSL
#1
Hallo, nach dem Update auf die neueste ISPCONFIG-Version kann ich keine Mails mehr per STARTTLS 587 / SSL 992 verschicken. Ich bekomme im Mailclient eine Fehlermeldung, mail.log siehe weiter unten. Ohne Verschlüsselung kann ich auf Port 25 problemlos verschicken.
Weiß jemand Rat?
May 10 02:57:39 smail postfix/submission/smtpd[30636]: connect from 46.128.91.251.dynamic.cablesurf.de[46.128.91.251]
May 10 02:57:52 smail postfix/submission/smtpd[30636]: NOQUEUE: reject: RCPT from 46.128.91.251.dynamic.cablesurf.de[46.128.91.251]: 554 5.7.1 <46.128.91.251.dynamic.cablesurf.de[46.128.91.251]>: Client host rejected: Access denied; from=<xxxxx@hyper-xxxxxxx.net> to=<xxxxxx@xxxxxx.net> proto=ESMTP helo=<xxxxx-win10>
May 10 02:57:53 smail postfix/submission/smtpd[30636]: disconnect from 46.128.91.251.dynamic.cablesurf.de[46.128.91.251] ehlo=2 starttls=1 auth=1 mail=1 rcpt=0/1 rset=1 quit=1 commands=7/8
#3
Hier, vielen Dank fürs Drüberschauen
# Postfix master process configuration file.  For details on the format
# of the file, see the master(5) manual page (command: "man 5 master" or
# on-line: http://www.postfix.org/master.5.html).
# Do not forget to execute "postfix reload" after editing this file.
# service type  private unpriv  chroot  wakeup  maxproc command + args
#               (yes)   (yes)   (no)    (never) (100)
smtp      inet  n       -       y       -       -       smtpd
#smtp      inet  n       -       y       -       1       postscreen
#smtpd     pass  -       -       y       -       -       smtpd
#dnsblog   unix  -       -       y       -       0       dnsblog
#tlsproxy  unix  -       -       y       -       0       tlsproxy
submission inet n       -       -       -       -       smtpd
  -o syslog_name=postfix/submission
  -o smtpd_tls_security_level=encrypt
  -o smtpd_sasl_auth_enable=yes
#  -o smtpd_reject_unlisted_recipient=no
  -o smtpd_client_restrictions=$mua_client_restrictions,reject
#  -o smtpd_helo_restrictions=$mua_helo_restrictions
#  -o smtpd_sender_restrictions=$mua_sender_restrictions
#  -o smtpd_recipient_restrictions=
#  -o smtpd_relay_restrictions=permit_sasl_authenticated,reject
#  -o milter_macro_daemon_name=ORIGINATING
smtps     inet  n       -       -       -       -       smtpd
  -o syslog_name=postfix/smtps
  -o smtpd_tls_wrappermode=yes
#628       inet  n       -       y       -       -       qmqpd
pickup    unix  n       -       y       60      1       pickup
cleanup   unix  n       -       y       -       0       cleanup
qmgr      unix  n       -       n       300     1       qmgr
#qmgr     unix  n       -       n       300     1       oqmgr
tlsmgr    unix  -       -       y       1000?   1       tlsmgr
rewrite   unix  -       -       y       -       -       trivial-rewrite
bounce    unix  -       -       y       -       0       bounce
defer     unix  -       -       y       -       0       bounce
trace     unix  -       -       y       -       0       bounce
verify    unix  -       -       y       -       1       verify
flush     unix  n       -       y       1000?   0       flush
proxymap  unix  -       -       n       -       -       proxymap
proxywrite unix -       -       n       -       1       proxymap
smtp      unix  -       -       y       -       -       smtp
relay     unix  -       -       y       -       -       smtp
#       -o smtp_helo_timeout=5 -o smtp_connect_timeout=5
showq     unix  n       -       y       -       -       showq
error     unix  -       -       y       -       -       error
retry     unix  -       -       y       -       -       error
discard   unix  -       -       y       -       -       discard
local     unix  -       n       n       -       -       local
virtual   unix  -       n       n       -       -       virtual
lmtp      unix  -       -       y       -       -       lmtp
anvil     unix  -       -       y       -       1       anvil
scache    unix  -       -       y       -       1       scache
# Interfaces to non-Postfix software. Be sure to examine the manual
# pages of the non-Postfix software to find out what options it wants.
# Many of the following services use the Postfix pipe(8) delivery
# agent.  See the pipe(8) man page for information about ${recipient}
# and other message envelope options.
# maildrop. See the Postfix MAILDROP_README file for details.
# Also specify in main.cf: maildrop_destination_recipient_limit=1
maildrop  unix  -       n       n       -       -       pipe
  flags=DRhu user=vmail argv=/usr/bin/maildrop -d vmail ${extension} ${recipient} ${user} ${nexthop} ${sender}
# Recent Cyrus versions can use the existing "lmtp" master.cf entry.
# Specify in cyrus.conf:
#   lmtp    cmd="lmtpd -a" listen="localhost:lmtp" proto=tcp4
# Specify in main.cf one or more of the following:
#  mailbox_transport = lmtp:inet:localhost
#  virtual_transport = lmtp:inet:localhost
# Cyrus 2.1.5 (Amos Gouaux)
# Also specify in main.cf: cyrus_destination_recipient_limit=1
#cyrus     unix  -       n       n       -       -       pipe
#  user=cyrus argv=/cyrus/bin/deliver -e -r ${sender} -m ${extension} ${user}
# Old example of delivery via Cyrus.
#old-cyrus unix  -       n       n       -       -       pipe
#  flags=R user=cyrus argv=/cyrus/bin/deliver -e -m ${extension} ${user}
# See the Postfix UUCP_README file for configuration details.
uucp      unix  -       n       n       -       -       pipe
  flags=Fqhu user=uucp argv=uux -r -n -z -a$sender - $nexthop!rmail ($recipient)
# Other external delivery methods.
ifmail    unix  -       n       n       -       -       pipe
  flags=F user=ftn argv=/usr/lib/ifmail/ifmail -r $nexthop ($recipient)
bsmtp     unix  -       n       n       -       -       pipe
  flags=Fq. user=bsmtp argv=/usr/lib/bsmtp/bsmtp -t$nexthop -f$sender $recipient
scalemail-backend unix    -    n    n    -    2    pipe
  flags=R user=scalemail argv=/usr/lib/scalemail/bin/scalemail-store ${nexthop} ${user} ${extension}
mailman   unix  -       n       n       -       -       pipe
  flags=FR user=list argv=/usr/lib/mailman/bin/postfix-to-mailman.py
  ${nexthop} ${user}
dovecot   unix  -       n       n       -       -       pipe
  flags=DRhu user=vmail:vmail argv=/usr/lib/dovecot/deliver -f ${sender} -d ${user}@${nexthop}
amavis unix - - - - 2 smtp
        -o smtp_data_done_timeout=1200
        -o smtp_send_xforward_command=yes
        -o smtp_bind_address=
127.0.0.1:10025 inet n - n - - smtpd
        -o content_filter=
        -o local_recipient_maps=
        -o relay_recipient_maps=
        -o smtpd_restriction_classes=
        -o smtpd_recipient_restrictions=permit_mynetworks,reject
        -o mynetworks=127.0.0.0/8
        -o strict_rfc821_envelopes=yes
        -o receive_override_options=no_unknown_recipient_checks,no_header_body_checks
        -o disable_dns_lookups=yes
127.0.0.1:10027 inet n - n - - smtpd
        -o content_filter=
        -o milter_default_action=accept
#5
Nee, die Zugangsdaten sind definitiv richtig. Wie ich weiter oben schon ausführte, mit PLAIN auf port 25 geht es ja mit den GLEICHEN Zugangsdaten.
#6
Dann korrigiere doch mal Deine master.cf. "-o smtpd_client_restrictions=$mua_client_restrictions,reject" gehört da definitiv nicht rein.
 -o smtpd_client_restrictions=permit_sasl_authenticated,reject
#7
Danke für die Antwort, soll ich das so korrigieren, wie du das da angehängt hast?
Ich habe selbst KEINE Änderungen in der master.cf vorgenommen, Ich habe lediglich ein UPDATE auf die neueste ISPCONFIG Version vorgenommen (wegen SSL) und dann anschließend das Script LE4ISPC laufen lassen, mehr nicht. Danach hatte ich das o.g. Phänomen.
#8
Ich habe keine Ahnung, was dieses Script macht. Was Du in deiner master.cf hast, kommt nicht durch ein ISPConfig-Update. Die Zeilen oben stehen so in der offiziellen Installationsanleitung. Vielleicht hast Du den Fehler ja schon immer gehabt.
#9
Nee, vor meinem Update hat STARTTLS und SSL bei Mail ja funktioniert (mit einem self-signed). Weil ich aber Letsenrypt überall einsetzen wollte, hatte ich das Update gemacht und das Script laufen lassen und war dabei dieser (ich nehme an Tills) Anleitung gefolgt:
https://www.howtoforge.com/tutorial/securing-ispconfig-3-with-a-free-lets-encrypt-ssl-certificate/
Trotzdem herzlichen Dank für die Hilfe, ich habe die Änderungen eingefügt und funktioniert alles. Ich rätsle aber dennoch, wo diese Änderungen denn herkommen mögen. Denn die master.cf wurde exakt an dem Tag des Updates neu erstellt, wie ich am Filedatum sehen kann. Eine ältere Version enthält die Zeilen, die du oben beschrieben hast. Seltsam...
